 Plane for Rossi 45 >
Plane for Rossi 45
Plane for Rossi 45
Old 06-30-2008 | 01:14 AM
MetallicaJunkie's Avatar
Default Plane for Rossi 45
what would be a good fast flying arf for under 200 ...the cheaper the better
Old 06-30-2008 | 01:22 AM
Default RE: Plane for Rossi 45
you can look into the Scanner by pheonix, its very light and the rossi should power it well.
Old 06-30-2008 | 08:11 AM
great planes viper
Old 06-30-2008 | 12:03 PM
the scanner is nice, but i have an LA Racer an they are very similar .... i wouldn't mind a viper, if it had a conventional tail...
anything else?
Old 06-30-2008 | 12:45 PM
tIANci's Avatar
The Viper is very different in the way it flies compared with a Scanner, LA Racer etc. Its faster for sure ... Other than this you do not have much choice as your budger is 200 and you do not want something similar to the LA Racer.
Old 06-30-2008 | 04:52 PM
what other options would i have if i raised my budget?
Old 06-30-2008 | 10:24 PM
My Feedback: (27)
These engines lend themselves to profiles best due to the half/pipe location. They are really strong and would pull most of the current 46 size profiles very well.
Old 07-01-2008 | 12:50 AM
tIANci's Avatar
Mr Junkie ... what sort of plane do you wanna fly? My personal experience with the Rossi 45 is that she is good for either full or low throttle only. Never tried her for 3D so I can't really say much. As for fast, the Viper is fast and not too costly. Do check the mounting if you wanna purchase that plane. Any other plane is about the same. I had my Rossi on a WM Sky Raider Mach II, she was decently fast.
Old 07-01-2008 | 10:38 AM
i was browsing the extreme prop section , an ran into some delta airplanes..... ive never had a delta type aircraft
Old 07-02-2008 | 01:45 AM
yes if you consider the Viper put a tuned pipe on the rossi and this combo will keep your eyes focused.
