Cermark Pitts Elevators >
Old 05-18-2003 | 12:51 PM
Default Cermark Pitts Elevators
Just got the new Cermark Pitts and it looks great. Looking at the elevator though, I was considering using the two servo cutouts in the rear of the plane for dual elevator servos instead of using one servo and a metal torque rod. Then I would put a single servo in the fuselage for a pull-pull system on the ruder. Anyone else done it this way?
DK
Old 05-18-2003 | 12:58 PM
dkflyer
I have the new Pitts on order and am planning to use a single rudder servo and two on elevator.
What are you using for power?
tfacr
Old 05-18-2003 | 09:09 PM
I have a new YS 1.40 sport to put in it. Hoping that will be enough. I'm guessing the airplane will weigh about 10 1/2 pounds when its done.
DK
Old 05-18-2003 | 09:41 PM
Let me know how it's going - Mine is on order (about 2 weeks) and I update you when I start on it.
Cheers
tfacr
Old 05-19-2003 | 12:21 AM
Anyone know what prop size would be best for this airplane with the YS 140 sport?
DK
Old 05-19-2003 | 12:42 AM
LuvBipes's Avatar
DKflyer, I had the old verison w/ a Saito 150 and all the servos in the middle fuse using the recomended (at the time) pull/pull setup. The plane was quite nose heavy which required about 3 oz of lead in the tail.
Assemble the plane w/out the elevator servos and balance it. If it's nose-heavy like mine was, by all means stick the elevator servos in the tail.
