CG location on Cermark Pitts
My Feedback: (25)
I balanced mine with a fingertip right behind the top rear cabane mount. Put your finger behind the cabane, with your finger just touching it and lift, it should go nose down just a bit. Mine flew (fly's; I sold it) great at that point. Snaps and spins were great, stall was just right.
The book actually states the balance point as being just behind the leading edge of the bottom wing, and that translates to just behind the cabane on the top.
Hope this helps, you'll love the plane. It is a keeper.
Jon
Jon
i had one of these and it was nose heavy by the book. Very nose heavy but i may have messed up. I dont know why they dont tell you were it balances in relation to the top wing. I thought it said a 1/4 or something IN FRONT OF THE LEADING EDGE OF THE BOTTOM WING. Anyway if your to nose heavy it will drop like a rock when you throtle back. Put some power back in and it will kind of harrier in with full elevator. Its not that scary or anything just remember to add some power if your nose heavy on test flight or it will wind up splaying the gear and possibley breaking some wood. After some tail weight she was an excellent flier and a real *****cat to land. Its been a while but i thought i was by the book when i balanced.
NM
Originally posted by rcpilot_971
dose any one know the CG lacation on the Cermark Pitts
Thanks Tim
Thanks Tim
Jim
My Feedback: (50)
ok hanks for the info
I have a saito 150 for power but I had to add a on bord glow & a extra battery I put both batterys 1100 & a 1400 mil right behind the bottom wing & put the onbord glow unit under the cowl up front seems to ballance out ok at 1/4 in behind leading edge hangs flat I bout this plane used with no motor or radio gear so we will see how she flys soon as we get some nice weather and no wind
Thanks Tim
Thanks Tim
