Cherokee ARF Great Planes
My friend just purchased a GP Cherokee ARF. He is in the process of purchasing an engine. What are you guys using in your Cherokee's? I told him to buy either an OS 40 or 46 AX. He wants to put a OS 55 AX but I think it will be too heavy and overpowered.
Any advice or modifications you can recommend before he start to build will be appreciated.
Mike
Mike
RE: Cherokee ARF Great Planes
A .55 won't really be too heavy but it is more power than necessary. The .46-AX or something similar is a great match for the plane.
My Feedback: (8)
Flew mine with the O.S. .46 AX and it had PLENTY of power; mounted it as per the instruction manual with no problems. The Cherokee flew very nicely (until my new Spectrum DX7 radio CRAPPED out [:@] [:'(] ).
I was over at my buddies helping him put together his new Cherokee. I have got to say the quality is not as good as I expected. One of the wing servo covers is wrong, the rear horizontal stab is warped and we tried to get the wing joiner tube into the left wing for over two hours!!! The tube slides in the right wing half fine. The joiner only slides in ~4 inches and you have to use pliers to get it out. [:@] Let's not forget the mismatch color on the cockpit cover. It's a couple of shades darker red then the whole plane. Is anyone else having the same issues? What did you do for the wing joiner tube issue? He must of got a lemon!
Mine has the paint/monokote color match issue but I've just come to expect that on a lot of ARF's. Otherwise, the construction quality and assembly is excellent.
My Feedback: (8)
Tundraman: I had a lot of "quality" issues on my Cherokee ARF (as discussed in another thread here) but I can say this...once the model was in the air it flew GREAT. I was very surprised at how well the ARF actually handled in flight and was pleasantly compensated for the assembly hassels. As I said, if my new Spectrum hadn't crapped out I'd still be enjoying the Cherokee. Hang in there and after carefull assembly I believe you'll like the flying characteristics of this ARF.
ORIGINAL: sqeakalong
Mike
If the problems are too bad, you ay also want to call Great Planes and explain what is going on. They generally stand behind their products pretty well.
My Feedback: (8)
Hi, Mike.
I had no problem with the wing joiner; the wing slipped together very easily. In this case I believe Chuck has the best sugestion for your problem. Call Great Planes...the wing center section is one place you don't want any issues cropping up. The wing joiner should slip in without requiring pliers to get it out. You need a new wing panel to replace the misbuilt one in your ARF box.
Soft landings.
Soft landings.
Thanks guys. I agree. I actually sent GP a email Saturday evening but I am going to follow up with a call tomorrow afternoon. I guess I'll wait to see what they say.
Mike
Mike
CT
I was planing on buying the spektrum Dx7 2.4 and would like to know what was the problem with yours. I have also thought about the Futaba 7C 2.4 but read they also have there problems. I think I'll get the Spektrum anyway and hope for the best.
My Feedback: (8)
On my Spectrum DX7: The firmware failed, the failsafe failed. Complete radio failure while inverted and just when I was beginning an inside half loop. Motor went instantly from idled back to full throttle right before the total failure. The plane went STRAIGHT into the ground...when about 18" of the tail popped off the break line was near perfect on all four sides...like it had been sawed off. Hoping for the best can be a bit dramatic at times. I purchased a new Futaba radio.
CT
Thanks Sqeakalong for that info. Has anyone else reading this form had this problem or any other problems with the Spektrum DX7? Thanks again. Dave.
My Feedback: (283)
ORIGINAL: tundraman
My Feedback: (283)
Hi, Here is a idea reguarding new or repaired radio systems. I never fly a new, repaired or a radio that has been crashed but seems to work ok in a new model or model I really care about. I have been flying for 40 years and many years ago I retrived a crashed, I should say damaged trainer from our trashcan at our local field and repaired it to use a a test plane. I leave the servos in it and just use the receiver and battery from the raido being tested. I fly / test the radio for 10 full flights. This may seem boreing but it has saved me and a lot of my budies a several planes over the years. I have loaned it out many times and it has been repaired many times as well almost to the point its safty for flight has been questioned on many ocations. This model has to have over 1000 flights on it over the years and is on it 3rd set of servos and 4th engine. For the most part its testing is boring and I normaly let some one at the field fly it a couple times. But when there is a problem it is worth it not to loose a good model.
TheRcav8r
TheRcav8r
