 Phoenix Extra 300s engine >
Old 10-02-2008 | 04:38 PM
Default Phoenix Extra 300s engine
Is an OS 61FX with a pitts muffler too much for the Phoenix Extra 300s
please reply
Hulio
Old 10-02-2008 | 04:56 PM
Default RE: Phoenix Extra 300s engine
I don't know what elevation you're at but to answer your question, no. I have one and live a 7,000'. I first had an OS FL70 four stroke on it and had a heck of a time trying to keep it flying. I now have and Super Tigre 90 two stoke on it and its by no means over-powered. The plane is built pretty well, just heavy.
Old 10-02-2008 | 05:02 PM
I just want enough engine to get me off the ground with no problems. I had a Sig Something Extra with the an OS 46AX on it and I didn't like the way it took off in the grass! I know the Phoenix 300s is heavier than the somethin extra.
I would rather have more power than not enough on take-offs.
Hulio
Old 10-02-2008 | 11:55 PM
Jetdesign's Avatar
My Feedback: (8)
I've had a couple of Phoenix planes- built very well, a tad heavy though the Extra is only 3.5lbs on Towers site (misprint?). If I were to get the Extra, I would use a 61. Never hurts to check the firewall and add some more glue.
However, something sounds wrong with your 46AX not getting planes off the ground. I fly off a grass strip and my 46AX pulled my Nexstar, Dolphin, and Venus 40 off with no problems - 3/4 throttle for the Nexstar, less for the Dolphin, and I use full throttle on the Venus just because I'm AMAZED by the ground speed I get in such a short distance!
What prop are you using? The Venus 40 specs heavier than the Somethin' Extra, so something is definitely wrong with your setup. I broke the 46AX in with an 11x5, and switched to a 12x5 after 5 or so gallons (10% nitro) - plenty of pull for a 40 size plane.
