Kyosho .40 Cap - Monokote Colors
NY
FYI...Had a little "wing ding" and picked up some Monokote trim sheets.
These colors match the Kyosho Breitling Cap 232 40 perfectly:
Monokote Yellow (not "Cub Yellow")
Monokote "Missile Red" (not "Dark Red")
The blue is very close, but not perfect:
"Insignia Blue" (not "Royal Blue")
These will be very handy since the covering on this airplane has a tendency to peel, particularly on the leading edges. These trim sheets are adhesive backed and apply beautifully using windex.
For those not familiar with the Windex technique: spray the surface where you want to apply the trim with a fine mist of Windex. Slide the trim piece into place and blot dry with a paper towel. Allow it to dry for a while before handling
TX
i knew about these what i wanna know is how it flys because im going to get one after christmas ill be flying my new hanger 9 AT 6 with boredom by then and i will want somthing new
NY
It flies great. I put an OS 46 FX in it. The power is ok, but not incredible. I have an OS 50 sitting around, and I think that's going in it while it's on the bench.
