Hangar 9 Twist 60
PA
Hangar 9 Twist 60
I have just completed the subject build. Page 22 of the manual states the "CG" specs are 5 7/8 to 6 1/2 inches back from the leading edge of the main wing.
I cannot get close to this range. I have attempted to balance the bird , inverted as stated in the manual, using a Great Planes "CG" stand. I would have to add well over 5-ounces of lead way far back on the tail in order to come close to this "CG" range.
Has anyone else had this issue? How did you resolve it? What am I doing wrong?
Thank you!
Smacka
Thank you!
Smacka
TX
RE: Hangar 9 Twist 60
Which engine are you going to use ? I recommend at least to start with go with the forward cg suggested - maybe even 5 1/2. After flying it you can further adjust if necessary. Mine lands a bit tail heavy with a 3 point landing stance with cg at 6 powered by a saito 91. It still has a half tank of fuel left after a 10 minute flight - this would make it fly more tail heavy if the tank was closer to empty.
PA
Hi Delman:
I have installed an Evolution .61, which is another reason I am puzzled by the "CG" issue. I was thinking with a .61 engine, hitting the stted "CG" range would be a no brainer. Boy, was I ever wrong.
Thank you for your help!
Smacka
Smacka
TX
The evolution 61 two stroke is probably 3-4 oz heavier than the saito 91 including mufflers - also used a dubro 1 oz spinner nut instead of the regular spinner.
PA
Nope, not until next spring. I was able to work through the "CG" issue. I located the battery under where the main wing bolts to the fuselage, and was able to get the balance point at 5 3/4". I believe it will work just fine here.
Keeping my fingers crossed. ..
Thanks for your input!
My Feedback: (34)
MI
Hi.........I mounted the elevator & rudder servos at the rear with steel linkage rods & have the EVO 100 2 stroke on the nose. I also balanced it at 5.00 inches back & it flies better there. I get no ballooning on final & it has unlimited vertical. As stated above, the recommended CG is too far back.
Tcat
Tcat
PA
Thank you all for your input! The last thing I need to do is to install one-inch servo arms (arrived in the mail today) on the elevator and the rudder so I can get the recommended surface throw. Right now, I cannot get the full throws. I already had one-inch arms on the ailerons.
I believe she will fly her nuts off
Thanks again for your help!
