hanger 9 edge >
hanger 9 edge
hanger 9 edge
Old 05-28-2003 | 12:03 AM
My Feedback: (46)
Default hanger 9 edge
I am about to start putting an edge together, I am planning on using aq zdz40rv, the plans only call for 5 servo's. what I need is for some of you guy's with experience on this plane to tell me what your setup is like as far as servo's & control's go. Any help with this matter would be much appreciated. I will be trying to 3d with this plane.
Gil
Old 05-28-2003 | 04:10 AM
My Feedback: (12)
my setup is 2 servos in rear, 2 for ailerons, 1 for rudder and throttle.
flew fine the first flight. havent been able to make it back for subsequent flights.
YS 140L, 12.5lbs
engine wieghs 2.8lbs with H9 mount, slimline muffler for smoke
zdz would be a little heavier i think...
Old 05-28-2003 | 04:19 AM
My Feedback: (46)
Ron:
You used two in the rear for the elevators, two for the ailerons, one for rudder on pull pull & one for throttle???
This is pretty much how I plan on doing it. Let me know if I got this right!!
Gil
Old 05-28-2003 | 07:23 AM
My Feedback: (12)
yep, you got it right.
i am pondering putting in my poulan 46cc.. but only after i get used to it in a test stand and i get more flights out of my edge/YS140 setup... we will see...
show us pics if you put the zdz 40 in...
Old 05-28-2003 | 07:26 AM
My Feedback: (46)
I'm thinking of the zdz, I have a fox 3.2 I am also thinking about, what do you think, can it hold together with the fox??
Gil
Old 05-28-2003 | 07:28 AM
My Feedback: (12)
it should, with the right mods. lots of power and wieght there from what ive read here and on a web site showing the conversion...
i saw a h9 edge in hobby shop with a gasser in it. not sure what size, looked 2.8-3.2 ish in size. didnt ask. looked like it had time on it, and didnt look too bad.
Old 05-28-2003 | 07:32 AM
My Feedback: (46)
I was running the fox in a midwest extra, it was awesome right until it's demise, a successful attempt to mix balsa & dirt. The extra & the edge are very close in size, I think I will try it & save about $500 bucks.
Gil
