cleaning an ARF when you are done... >
Old 03-18-2002 | 08:28 PM
My Feedback: (7)
Default cleaning an ARF when you are done...
What do you guys use to clean monokote when you are done with assembly. To get the glues marks, finger prints and such off.
Old 03-18-2002 | 08:36 PM
http://rcuniverse.com/showthread.php...851&forumid=63
Old 03-18-2002 | 08:58 PM
My Feedback: (7)
not looking for a field cleaner, but something strong to get glue marks and stuff out without damaging the monokote. Maybe some type of thinner?
Old 03-18-2002 | 09:01 PM
How 'bout CA Debonder? Ever tried it? Works great.
Old 03-18-2002 | 09:18 PM
Try acetone'It work's great but you should try it on the bottom of the plane first in a small area to make sure it won't harm the covering.Just use a small amount.You can get it at any hardware. Tim.
Old 03-18-2002 | 09:20 PM
w0mbat's Avatar
I use denatured alcohol then ammonia free glass cleaner to polish the finish.
Old 03-18-2002 | 11:22 PM
shill's Avatar
My Feedback: (22)
I use nitromethane to remove CA from the monokote. Then use rubbing alcohol to clean up.
Old 03-18-2002 | 11:25 PM
A little lacquer thinner on a rag works great. Be sure to work in a well ventilated area.
Later
Nate
Old 03-19-2002 | 12:54 AM
I use trim solvent. Smells like gasoline. The wife just loves it.
Old 03-19-2002 | 01:53 AM
Hey!
I clean all epoxy and CA overruns right after glueing to make the final job easier and keep the plane looking decent. For a final wash to clear the fingerprints and other assembly dirt I use a paint thinner soaked rag.
It leaves a clean " As seen on TV $19.95! Buy Now!", streak free mirror shine. Sorry I'm up all hours of the night.... :stupid:
Filip
Old 03-19-2002 | 05:12 AM
Acetone on MoneyCoat. Test it before you try it on something else
Old 03-19-2002 | 12:32 PM
Go to Home depot, in the paint department and get a small can of "Goof Off" it works great!!! Daz...
Old 03-19-2002 | 06:15 PM
posted basically this same mix a while back, but am going to try the following ratios this year. Works great for me, and CHEAP!!! Like maybe a buck for a full fuel jug!
empty and clean fuel jug
2 cups 99% alcohol
fill 3/4 with water
add 1/2 cup sunlight dish soap.
mix
follow this order or you'll just end up making bubbles.
Rich
Old 03-20-2002 | 04:42 PM
My Feedback: (7)
is the laq. thiner safe for decals also? I guess a test would be a good idea.
Old 03-24-2002 | 05:04 AM
My Feedback: (7)
FYI,
Lacquer Thinner rocks!!!!!
Just a little bit on a rag with some very light rubbing removed every trace or both epoxy and CA. No streaks, and it left the monokots shinny....
Old 03-24-2002 | 10:01 PM
Razor-RCU's Avatar
My Feedback: (50)
Default Windex
Windex....LOL
Old 03-25-2002 | 02:42 PM
My Feedback: (506)
Acetone works fine on ultracoat.
It will clean the printing off decals, though. Guess how I learned that.
