 Ultra Stick with Eclipse 7 >
Old 11-04-2008 | 08:37 PM
spadeng's Avatar
Default Ultra Stick with Eclipse 7
I set up my Eclipse 7 to run my Ultrastick, I set up the Mixes to have Aileron/Flap mixing and Elevator/Flap mixing and run the flaps off the gear swith to use the Two switch CROW mixing method (or perhaps it is more speed brakes as when the throttle is not mixed in to decrease the braking effect as the throttle is increased), It seems to work really well as I ran the controls threw in the dining room table. I plan on using only one mix at a time. I know there were a lot of questions about this set up and this is the only way to do it with this radio, Just wondering if anyone has ran this set up and the results they have had with it.
Old 11-05-2008 | 05:20 PM
Default RE: Ultra Stick with Eclipse 7
I tried, I never got as far as You are now. Loved the plane, but the radio never did the plane justice. I just thought that the Eclipse 7 didn't have it in it.
John
Old 11-05-2008 | 06:45 PM
spadeng's Avatar
I think I pushed the radio to its limit, I just dont want to buy another radio, expecially if this works, I was looking at a JR XP8103, then I would want a module like the spectrum module in my HiTec, I will see how the weather is this weekend and fly it then.
