H9 Frenzy 100 help
KY
H9 Frenzy 100 help
I have a Frenzy 100 on the way with the Evolution 1.00 2 stroke. What servos should I use? Will a Bisson muffler help with this combo? Any finishing suggestions are appreciated.
TN
RE: H9 Frenzy 100 help
My experience with the Evolution 1.00 & Bisson muffler was not very good. I had a lot of dead-stick landings. Eventually came to suspect not enough muffler pressure. I've been advised to block one muffler exit, or restrict both exits. I have not tried it yet. Hope this helps.....
WA
It's not good to have a dead stick with a Frenzy. If you have a hard landing you'll end up ripping the landing gear out of the side. It happened to mine and I had to rebuild the sides and add the gear to the bottom.
Best combination for the Frenzy is with a Saito 125. Run 30% heli fuel and you will love the plane. Also I am using JR Sport 126 MG servos on a 6-volt pack.
R/C Foolish
R/C Foolish
ORIGINAL: Hanger9Guy
You can get a lot of 'completion' info from Horizon
http://www.horizonhobby.com/Products...ProdID=HAN4700
