H-9 25% Cap elevator and aileron throws >
Old 03-19-2002 | 02:21 PM
Default H-9 25% Cap elevator and aileron throws
I am setting up the throws on my H-9 25% Cap ARF. I plan to fly it mostly with pattern or IMAC maneuvers. Would you suggest that I use the throws in the instruction manuel or go with less throws.
Ed Kirtley
Old 03-22-2002 | 07:50 AM
You don,t need the 3D rates.the low rates will probably work good for you but you will end up with a little higher rates on the wings or it will be a slow roller on low.
