1/4 scale 3D with 160FX???? >
Old 03-19-2002 | 05:33 PM
Default 1/4 scale 3D with 160FX????
Guys could you post some suggestions on a good 1/4 scale plane for learning 3D w/a 160FX. I'm looking at the Lanier Edge 540, H9 Edge 540, and the Dave Patrick Ultimate. If you have any other suggestions or comments on these I'd be interested in hearing them. I am definately stuck on the 160 as a motor so that's a must but finding a combination to experiment with 3D isn't such a definate thing.
Old 03-19-2002 | 07:06 PM
My Feedback: (67)
I have the 160 on the H9 cap and love it. From what I hear it would be a good motor on any plane you have listed. I have yet to fly my H9 edge, but I am sure the 160 would fly it very well also. I have flown the lanier edge and I really liked it. A good stable plane, that landed really slow.
Old 03-21-2002 | 05:06 AM
Icebird's Avatar
Default OS 160
I have the OS 160FX on a DP Ultimate, and it's incredible. The Ultimate does the BEST blenders I've ever seen!!! A real 3D machine, hard to beat!
Old 03-21-2002 | 01:20 PM
RickP's Avatar
I have one on a GP Giles 202, It's my first 1/4 scale, but so far I am having the best performance with it. From what I hear the Lanier Edge would be the way to go. I'm hoping to get one next.
RP
Old 03-21-2002 | 01:37 PM
I'm going to use a 1.60 on a Great Planes Giles. I planned on using a 18x6 APC, what do you guys think/use.
Ken
Old 03-21-2002 | 05:29 PM
Default O.S. 1.60
I run the 18x6 Pro Zinger on my 1.60 in my Lanier edge seems like a good combinations
But i am waiting on my 18x6 Mejzlik carbon fiber from dons hobby shop now.....it should be even better!
Old 03-21-2002 | 06:21 PM
RickP's Avatar
Hey!
I want to get one of those CF Mejzlik props for my mill to, but don't they come with a 10mm pilot hole? I think the shank is 3/8" on the 160 (That's 9.5mm). Isn't it going to be to big? Has anyone done this?
Rick
Old 03-21-2002 | 06:34 PM
Default 3d plane
I have say the h9 cap, good 3d plane, but not w/ a 1.60 3d will be limited, gp 202 3d performance is better w/ the 1.60 however its not the best 3d plane, lanier edge probably would be good but have not flown this combo, personal favorite has to be the sig cap and 1.60, its by far the most 3d capable plane w/ 1.60 that I have encountered. icebird, just curious what you dp all up weight is? I have considered this combo, how neutral is it in a hover?
Old 03-21-2002 | 07:21 PM
Icebird's Avatar
Default DP Ultimate
It's pretty stable in a hover, not quite as solid as my Laser3D, but then not much is! :-) All up weight is between 11.25 and 11.5 pounds, without fuel. Obviously take off weight would be higher, I have a 16 ounce tank in it. I use an 18X6W APC prop, and find it great.
Someone asked about using a Mejzlik prop. Yes, the hole is too big, but that's easily fixed. I actually made it a little bit bigger, then put in a piece of brass tubing that fit the prop shaft exactly. I would guess it to be something like 3/8 ID, and the OD was just a bit larger than the hole in the prop. Cut a piece 3/8 inch long, and fit it in the prop, then enjoy!
