Falcon 120
AL
Falcon 120
I just built a Falcon 120 from Nitroplanes and it show the tank mounted with the fuel lines facing the rear toward the engine.It seems the clunk will be in the wrong place as the fuel goes down and you are climbing,has anyone mounted the tank with the lines facing to the rear on a pusher and it worked?
RE: Falcon 120
It's a bad idea to mount the tank with the stopper towards the rear.
I've four of these planes, and I've mounted the tank with the stopper facing forward on all.
You can merely run the lines over or beside the tank towards the back. Try to keep them as short as you can though.
AL
RE: Falcon 120
I have an OS 120...........The blocks holding the gear just fell out, looked like they were just tacked with hot glue.I wonder if I could put a header tank on it like a heli?
RE: Falcon 120
ORIGINAL: telejojo
I've found that this area gets a huge amount of stress, more so than in other planes, and re-inforcement is a MUST.
You also need to do something to distribute the force on the gear over a wider area.
The provided blocks merely concentrate the force right at the block, so the gear tends to rip out if you do something as simple as running off tarmac onto grass, at landing speeds.
It would be advisable to insert ply strips to re-inforce the gear retention areas, and distribute the force.
