radio setup
My Feedback: (31)
if i were doing it i would only have one receiver and one battery and switch and no power expander, but who am I to say what you need to do is what is gonig to make u feel the best about your setup......
That is my seup on a 33% Hanger 9 Cap 232
2-7955 ailerons
2-5955 elevators
1-5955 push pull rudder
1-5200 fromeo battery
1 switch
2-7955 ailerons
2-5955 elevators
1 switch
My Feedback: (204)
Hey Krayzyc, did you get your CG as per the manual, from the wing tips? Where is your CG at? mine falls in line but the airplane doesn't decend on landings and any tiny ele movemant causes it to balloon
My Feedback: (31)
no i used a CG machine and tried to figured were at the root those measurement would fall. I think i started off at 7 inches at root. Mine is almost hands off inverted with just a 1/8 to 1/4 of stick movement to fly inverted. I have flown my battery as far back as behind the hatch, right now its on the gas tank. I only fly with 8-10 degrees on the elevator i also have a -2 on the throtle to elevator at idle for perfectly straight downlines otherwise it pulls to the canopy. I also fly wiht no expo on the elevator so i know i am doing soft stick movements on this bird for it not to also ballon and a very slow air speed on landings.
ORIGINAL: magnumph
should i go with a power expander or one reciever and two batteries.
At the end of the day - everybody will have a different opion so find what works best with you and your budget - without compromising safety.
My Feedback: (31)
i have 4 gas birds flying and none of them have the expender
one does have 2 receiver as it was set up 7 years ago when 8411 was king (2 rec, 2 batteries, 13 servos)
my 46 ultimate is running one rec, one battery, 9 servos
i did what was confortable for me
the cap is running 7 servos one rec and batery
