Seagull ultimate biplane 90
IL
Well I got my tax return back and decided to splurge a little. I just bought the ultimate 90 and an OS 1.20 two stroke to go with it. I was wondering if u guys had any thoughts on this set up. I'm thinking the OS will haul it around pretty good... But i'm not sure if it will be capable of 3d or not. This is the first "large" bird I've bought. The rest of my hangar is .40 sized. Also can anyone tell me what the difference is between the ultimate 90 and the 1.20 because they look the same to me. Unless I've mis- read the specs or something. Any thoughts would be greatly appreciated!
Hi,
I have the combination you have and am just getting used to it (had about 10 flights). Well and truely unlimited vertical.
There are several threads on the seagull ultimate - I'll list them below. They'll answer most questions you have, and give some ideas and tips on building, and things to watch out for.
http://www.rcgroups.com/forums/showthread.php?t=693696
http://www.rcuniverse.com/forum/m_6135548/tm.htm
http://www.rcuniverse.com/forum/m_83...tm.htm#8368658
http://www.rcuniverse.com/forum/m_47..._1/key_/tm.htm
cheers
- Kevin
cheers
- Kevin
