Nose gear to much turn >
Old 03-23-2002 | 11:45 PM
Default Nose gear to much turn
I have too much turn in my nose gear. I have moved the nose gear to the outer hole and the servo adjustments all the way in. Is there anything else that I can try.
:spinnyeye
Thanks for any help
Old 03-24-2002 | 01:07 AM
There would be only two more options. Either lower the travel of the rudder via radio (EPA or Dual Rates) or buy a control arm for the nose gear that is longer than what you have.
