World Models Mustang or Zero
Im looking at both the world models Midget Mustang Racer and their Zero fighter 60. Id like to hear pros and cons for both as well as engines used.
Go here to my "el cheapo" webpage and check out a couple
www.geocities.com/slewfoot42/mlh
Now I own the Midget with a OS 1.08. An obvious overkill but that is me. I suggest nothing less than a .90
I also have the .40 size P-51. I bought it as a ARC. I run a ST.90. I also suggest nothing less than a .60.
Both of these planes are excellent.
Now with the Midget, it is a very sleak flyer. Approaches must be on the shallow side. if you come in to steep, it will not slow down.
Very good plane.
Also consider the Dago Red. Close friend has this with a 61FX. Goes very well.
Another friend has the Zero. I like Zero's but that one just does not do it for me. Out of all the planes WM provides, I think this is the runt of the litter.
Now on my Midget, I modified a few things like running dual elevator servos. Also i have the white version. if I had to do it again I would go with the yellow 50th anniversary. White is a real pain when any clouds are around.
Very good plane.
