sig cap 1/4 scale
sig cap 1/4 scale
I have a Sig Cap 231ex and saito 150, a lot of fun and does some 3d but not unlimited (partly due to power limitations, partly due to pilot limitations). I have it on an 8 channel radio, 6 volt battery, decent servos, electrodynamics glow igniter, tru turn spinner and recommend all of the above to you,
Peter
Peter
sig cap 1/4 scale
tx for the reply just came back from the lhs with the 1/4 sig cap ARF I did not order the moter yet but im thinking about geting the saito 180 over the saito 150.any other info first 1/4 scale, best servos to use on this moter plane combo tx.
sig cap 1/4 scale
It probably wouldnt hurt to have a little more power but I cant speak with direct experience about the 180. The 150 is fairly thirsty, the 180 will use even more fuel. I've got futaba 9202 servos but I'm sure other servos would be fine.
If you dont have the GP hinge cutting tool, now would be a good time to get it, along with a set of giant scale hinge blades. Hinging the control surfaces was the hardest part of building the kit and this tool really helps.
Peter
Peter
