wheel pants >
wheel pants
wheel pants
Old 03-26-2002 | 02:00 PM
Default wheel pants
I have a Sig S.E. and was wondering if there is a way to toughen up the wheel pants or maybe an aftermarket company that offers better pants than what comes with the plane?
I fly from a grass field and the pants only lasted about 5 flights before the left one broke. I would appreciate any ideas that anyone might have on the subject.
Old 03-27-2002 | 07:11 AM
Default wheel pants
I also fly off a grass field and mine have stayed on. I put on the
largest size tire that would fit and also raised the pant so that the bottom was about 1 1/4" off the ground. If you want to go
glass try www.fiberglassspecialtiesinc.com and match the length
and shape to the factory ones.
Old 03-27-2002 | 07:40 PM
My Feedback: (18)
Default wheel pants
I used 3" wheels and raised the pants a bit to fit. I have more than 160 trouble free flights off of grass fields. These wheel pants are tough enough when raised up a little.
Cheers!
Galen
Old 03-28-2002 | 02:26 PM
Default wheel pants
you can also glass the inside of the plastic pants to make them stronger.
Old 03-29-2002 | 05:42 AM
Default wheel pants
would epoxy on the inside of the pants help any?
Old 03-29-2002 | 04:19 PM
Default wheel pants
Epoxy by itself would just crack, you need to add some glass cloth to have strength with the epoxy.
