Hanger 9 P-51,FA200-TI, what prop.
I am a turbine guy looking to relax a little, just purchased a Hanger 9 P-51 and a Saito FA-200TI. I would like to put a 4 bladed prop on it, does anyone have a suggestion. Saito suggests a 16-8 to 18-6 two bladed, what would that be equal to in a four bladed rig. I don't want to relax to much, still like some speed.
Hello........
* Zinger four blade system w/center hub: http://www.zingerpropeller.com/4_bladed_propeller.htm (3.5" spinner #6600 $24), 13x6 #4133 $24, 13x6-10 #4137 $24, 14x6-10 #4146 $26.40, 15x6-10 #4155 $34.
* 2 to 3 and 4 converter: http://www.zingerpropeller.com/_2_blade_.htm
* TruTurn aluminum 4 blade spinner and Saito adapter:TRU3504B spinner, $51.99, and adapter #TT-0717-A, $13.95.
* 4 BLADE APC Props: 15.5x12(APC415512), $18.95; 13.8x10(APC413810), $18.95; 13x13(APC413013), $18.95; 11X9(APC4011090), $9.95; 11x6(APC4011060), $9.95; 10x6(APC401060), $8.95; 9x6(APC409060), $7.95.
* VarioProp pitch adjustable 4 individual blade prop system: http://www.eam.net/Varioprop/Intro_Vario.htm (I can't get a response from email)
4-blade-hub, Size 12C: $34
Alu-Spinner-12C, Nr 1201, for 8 x 1.0mm (Saito is 1.25mm), 4.1 grams, $3.40
Blades Nr 330/12, Dia.-13.0", 20.2 grams, Redline 9.000, Desc.- High RPM, $2.50
Specific to the Saito 100:
2 blade-13x8, 14x6, 14x8, 15x8, 16x6, 17x6, 18x5, 18x6; 3 blade-14x7, 13x8 (Zinger); 4 blade- 14x6, 13x7, 13x6 (Zinger), 12x8, 11x9(APC4011090).
I will assume you are talking about the new 77 inch spand Mustang. So, let us know how it performs with this engine...please!
I personally would go with the Zinger 4 blade system mentioned above, probably around 15x6, something in that range. This one also seems to have a more scale appearance than the APC or others. Yes, please do let us know how this engine and aircraft combo performs, as there are a number of us who are drueling with curiosity before we shell out the cash.
I GOT THE MESSAGE TO LATE. ON ORDER IS A BOLLY 15.5 X 8 4 BLADE CARBON PROP AND A TRUE TURN SPINNER. I WILL LET YOU GUYS KNOW HOW IT WORKS OUT. I HOPE IT WON'T BE TO MUCH.
NICK.
NICK.
