phoenix super decathlon canopy
PA
Well, the plane is flying very well. After I got back from the field yesterday I decided to smooth out a wrinkle in the coating near the firewall on the left side of the fuselage. I used an old hiar dryer that was in the basement. It worked well smoothing out the wrinkle. After putting the dryer away I walked back over to the work table and noticed that the heat from dryer had warped the canopy! I recall reading about a crash of a SD on the build thread here. Was wondrering if the person still had he remains. If so. please send me a PM and I'll make an offer. Looks like the only way to get a new canopy is to order the entire Fuselage assembly.
I've heard that Seagull and Phoenix are almost identical. You could try the Seagull canopy. If it doesn't work you are not out a lot of money.
http://www.horizonhobby.com/Products...ProdID=SEA2085
John
John
PA
Good idea, I just didn't think the heat would distort it the way it did. I will figure something out. Live and learn. Anywhere near plastic from now on, I will use the cover iron!
John, nice link! I wish I would have seen that a few months ago when I was looking for a canopy for my Phoenix SD. Unfortunately, I now have a need for the canopy, fuse, wing, etc lol. I too learned the hard way about heat guns and canopy's on my GP Reactor. Just trying to shrink a few wrinkles in covering, and warped the canopy. Fortunately, that one wasn't too bad...
PA
ORIGINAL: wyo69cowboy
PA
ORIGINAL: JNorton
John
John
ORIGINAL: billd76
Got the seagull canopy in the mail yesterday. It's at least 1/4 inch wider. At the moment I don't see anyway to make it work. Will think about it more. I think I have a plan to straighten out the orginal one as well.
ORIGINAL: JNorton
John
John
PA
ORIGINAL: Mr67Stang
I wish I had seen this thread sooner. I ordered the Seagull canopy for mine as well and found the same issue. I cut mine down the middle, overlapped it, and glued it together with canopy glue. The results were less than satisfying so I am back to my other plan. I will build a front canopy out of wood and cover it.
ORIGINAL: billd76
ORIGINAL: JNorton
John
John
Yeah, I wish I was a better modeler. I read up some on vacuum forming, but don't have any of the equipment or even much scrap wood to build a vacuum box, so it's not really cost effective for me to build one. Might still try it someday; it's frustrating when you only need one part and have to buy a whole lot more (i.e. fuse for this plane) to get what you need. I tip-stalled my SD and it ripped out the front wing bulkhead, but I was able to repair the fuse and bulkhead quite easily. My canopy was torn down the middle with a jagged rip, and I ended up using clear packing tape to fix it. Looked okay, but not great.
PA
Thes decathlons have very strong wings and week cocpit framing. So whenever you catch the wing it ripps out the front mounting location and subsequently destroys the front windshield. I can't imagine they are unaware of this. Even if I was willing to buy a new fuse to get the windshield I would only use the windshield as my fuse looks good enought that it would not be worth having to remove the tail feathers and install them in a new fuse. Yes this is a frustrating business practice and likely my last Pheonix model.
