Seagull PC-9 build
Through some turn of events i have access to a full kit brand new seagull pc-9 with everything ready to go, but this is for a others, and i was given an older model of the same plane still verry structurally intact however missing a large chunk of the entire right wing...
I'm not that new to building these things but would be about the first wing without anything of a plan to go off, so, does anyone out there have a slightly broken but still able to see the basic structure and roughly how its built wing of the seagull PC9. i'm asking for a one w/o covering because the left wing i have only has a small tare and is perfectly good, not worth pulling to pieces to create more work over..
cheers
cheers
Hi Ross
I also have this model, but my wing is still covered. However, I did stumble across this pc9 retract thread some time ago [link]http://www.rcuniverse.com/forum/m_3598534/mpage_4/key_/tm.htm[/link]. If you scroll to the bottom of the page, there are some images posted of the wings without the covering that may be of use to you. Check out the other pages in the thread as well, as there are more images scattered around the place. Not sure how much help these will be, but at least they will show you what it looks like.
Hope this helps
Hope this helps
