Morris the Knife ARF
AL
I'm planning to buy the Morris "The Knife" soon.
I'd like to build it stock.
Are there any upgrades (pull-pull) that I should consider or that folks may feel I can't live without?
IL
It comes with the pull pull on the rudder and elevator. Make sure they work smoothly before hooking them up. Put a decient engine on it. I have a Webra .50 and it is AWESOME. Mine has no bad habits and flew right off the board. I did mount my tank on the outside of the fuse, opposite the engine. Great plane, you can't go wrong! Pete
"Ain't no substitute for cubes"
My Feedback: (67)
IN
Great plane, flies great "Stock". I would mount the tank outside the wing for conveinence but thats the only mod I would do. I have an os 46 fx and have plenty of motor left for pull out of hovers! A ys 63 will fly these nice too, as thats what I have on my su-do-khoi! Great Plane you'll love it! Probably the best hovering 40 size plane I have flown, and I have flown many! Happy flying
My Feedback: (16)
NJ
I just put one together (the arf) stock with no mods. The pull-pull looks wierd but works fine so far (about 8 flights). GREAT fun fly plane but not the most graceful thing in the air. I set up an elevator/flap mix as well as an elevator/ throttle mix. Lots of fun landing into a slight headwind with both mixes on, the plane just settles down gently like a helicopter.
My tail wheel bent first time out (landing vertically) you may want to upgrade it.
Lots of fun.
Lots of fun.
My Feedback: (67)
IN
The giant su-do-khoi is an easy flying plane. It really likes to hover! The knife hovers a little better than the su-do-khoi in my opinion. But the su do will do the neatest climbing flat spin I have ever seen. Both are excellent planes. Of you are new to hovering I would go with the knife. If you are already hovering the sudo or the top cap might make a better choice. They are just a little wilder. I really don't know why the knife hovers so well but it does. I learned to do rudder touches with mine. The plane almost makes me look good doing it too.
