 To glue or not to glue >
Old 02-22-2010 | 03:15 PM
Default To glue or not to glue
Started building the G.P Escapade and was wondering if the wing halfs need to be glued together. I recall reading other posts in which some perfered not to glue. Any thoughts?
Old 02-23-2010 | 09:58 AM
MinnFlyer's Avatar
Default RE: To glue or not to glue
Your call. Personally I prefer to have a two-piece wing.
Old 02-23-2010 | 11:53 AM
so the wing won't come apart when flying if not glued?
Old 02-23-2010 | 12:15 PM
MinnFlyer's Avatar
They can't. There is a strap holding them together and each wing-half is bolted to the fuse
Old 02-23-2010 | 12:30 PM
oldvet70's Avatar
My Feedback: (10)
Like many modern ARF's the Escapade has a 2 piece wing. Generally this is done to make transport of the wing easier, but the Escapade is a pretty small plane. It is not necessary to glue the wing halves together, they will not come off in flight. However if you have the room to transport the wing as one piece and if it gives you piece of mind you can glue them together, like MinnFlyer says it's up to you. But it's not necessary.
