WM GS Zero >
WM GS Zero
WM GS Zero
Old 07-23-2003 | 12:07 PM
Default WM GS Zero
Guess what arrived at my house yesterday in two big boxes. Yes the GS Zero that I ordered back in Nov. 2002. Worth the wait. On first inspection this is a well built plane. The fiberglass fuse is immaculate. Covering had 0 wrinkles. Retracts came installed with the wheels already installed. Both rudder and elevators are pull /pull. Retracts look pretty substantial and are spring loaded. Each retract requires its own servo. All hinges are preinstalled and look solid. A little tug proved that there is sufficient glue holding them. Only downside is the instruction book. Typical WM pretty short on wriiten directions, mostly pictures but anyone with a bit of previous experience should be able to figure it out.
