P-47
I didn't have any warped surfaces; it all went together fine. And yes, the wheels are too small and the retracts are too wobbly, but I do fly off grass, so it can be done if the grass isn't more than a 2-3 inches tall. I was thinking about making the wheel wells bigger like the World Models warbirds where they are wood-type cutouts instead of glue-in plastic wheel wells. It would probably give you another 1/2-3/4 inch for bigger wheels. Maybe someday.
Good to see your planes again, rcjake. Nice. |
RE: Model Tech P-47 Questions
ORIGINAL: yard-dart [quot . The plane went to gether nice but for $200.00 I didn't expect a set of nice retracts. |
Hey Yard Dart, I may be coming your way next month. A guy wants an amateur built aircraft recertified. I might still have the location of your flying field in an old message. [8D]
Jim |
:) Spell check will correct but I think it is wrong so I change it back
Just checking Hobby People's website for retracts and although guys here have been saying the P-47 comes with Magnum .40 size retracts Hobby People lists two different part numbers and prices for the Magnum retracts and Modeltech P-47 retracts. The Modeltechs cost 50% more:
237940 Magnum Retract Gear, Mech. 40 Size Mains 19.99 120203 Modeltech Retract Set - P-47 ARF 60 30.00 FWIW.............. |
planenutt,
I installed a Robart retractable tailwheel in my Jug (when I owned it!) and it worked great. Another servo was installed behind the others in the fuse to retract the tailwheel (via Dave Brown glass pushrod) and flex cable attached to the rudder servo for steering. It took me about 8 hours to figure it out the installation, get it installed and adjusted correctly. The Jug still looks great on those low fly-bys with all of the gear sucked up! My friend that bought my P-47 lets me fly it whenever I want...he knows that I really didn't want to sell it, but I hate to see a grown may beg & cry... |
ORIGINAL: skyking424 I am waiting on the brown truck to bring my air retracts and 3 1/4" dia. wheels. :D Thanks, -Tom |
1 Attachment(s)
Kmot, yes I finished my P-47 and everything works great!
Thanks for the pic's! Looks great! :D
skyking, I ordered the Century Jet gear. Another question, what propellor is that on your P-47?
-Tom |
Kmot the prop is a Zinger 14x5 four blade with a TruTurn hub on a Magnum 91 four stroke.
RE: RE: Model Tech P-47 Questions
where are you all getting the dummy radial engines.
and skyking424 have you used the the original paint scheme that comes with it, and is the prop real or just for looks. |
1 Attachment(s)
IL2rv-56 , The prop is real i fly with it all the time and the dummy engine came from Tower it is made by Top Flight
skyking: thanks! I also have ordered the Magnum 91FS. So, you can fly with that 4 blade Zinger? That is boss! :D
1 Attachment(s)
Good luck on your P-47 Kmot ! I ran the engine with the 3 blade prop a couple times on the ground before I put on the four blade to fly.
Thank you skyking!
Your P-47 looks great, and your pictures and info have given me lots of incentive to try to build mine as nice as yours. :) -Tom |
| All times are GMT -8. The time now is 11:16 AM. |
