Rear Mounting of Servos on U.S. 60
Need some help in the placement of the elevator servo, Rudder should not be a problem, was thinking of using a pull/pull system. How about the elevator? I don't know where to mount the servo or how to position in correctly? Any input?
I have already searched the threads... |
Rear mounted servos on US-60
1 Attachment(s)
Here is what I did with mine. After making the holes for the servos I glued ply strips inside the fuse for servo screws. I used pull-pull system on the rudder with rods and one servo for the elevator. Hope this helps you.
Rick |
| All times are GMT -8. The time now is 12:44 AM. |
