Small plane for a 46LA
<div style="margin: 0in 0in 10pt">I have an OS46LA with standard servos on a trainer. The engine is weak for a 40. I am bored with the trainer. I am trying to find a smaller plane I can transfer the engine and radio. All the smaller planes (.25 to .35) I have found require micro servos. Any idea what small plane I can find that will fly fast with a 46LA and standard servos? Any suggestion is appreciated.</div>
Thanks |
RE: Small plane for a 46LA
Skyraider Mach II. little bigger than what you described, but its a light, quick plane.<div>
</div><div>http://www.airborne-models.com/html/...?ProductID=147</div> |
If you want a plane that flies almost just the like a Sky Raider Mach II ... very stable and yet maneuverable ... the [link=http://www.thewingsmaker.com/airplane_details.php?name=Wingman%20II%20(GP)]Wingman II[/link] by The Wings Maker which is part of The World Models who makes the SRM2, will give you more speed.
But the Sky Raider is much tougher and if you are a new pilot, it will serve you better. Check out [link=http://www.abmshowcase.com/the_world_models/sport/sky_raider_mach_2/default.aspx]Sky Raider Mach II[/link] and [link=http://www.abmshowcase.com/the_world_models/sport/la_racer_40/default.aspx]LA Racer 40 ARF[/link] for more information on the Sky Raider and its sibling the LA Racer 40 that is a little nicer looking. |
I will second the LA Racer also the Great Planes Escapade 40 will fly just fine with that engine. Greg
I have an Escapade with a 46AX and it is still slow. The Escapade really needs a 55. A 46LA on an Escapade would be really slow.
I'll take a look at the Sky Raider. |
Have you tried different props on the escapade? I was flying a new Big Stick 40 with a thunder tiger 46 on it and was impressed with how fast it flew with an 11/5 APC prop. On landing I struck the prop tip and swapped it out for an APC 10/6 and man was that plane slow with the 10/6 on it. I wouldn't have believed what a difference it would have made if I hadn't just seen it with my own eyes.
A friend from about 10 years ago had a GP Sportster with an OS SF46 IIRC and that plane burned holes in the sky. |
You might want to try a Twist 40. It should fly fine with that engine. It's a great little plane that can fly like a trainer or with a little more engine will do anything you ask of it ! Good Luck
Maybe you can find the 30-40 class nitro plane model from our online store: http://store.hobby-china.com
Hope we can help you! |
Hobbychina I looked at the site you linked and decided would order an LT-40 ARF. For $58 it is a heck of a deal. The only problem is that you have to order a minimum of 100 units. I like that plane but can't see me needing quite that many in my garage. Can I buy just one or two of them? I might get my flying buddy to buy one also. One more question do you know what they are covered with?
LT-40 ARF out of stock now. We have same plane model in stock. Please visit our website: http://store.hobby-china.com Mark Long www.hobby-china.com <span class="b_"> </span></p> |
ORIGINAL: markhamregular I have an Escapade with a 46AX and it is still slow. The Escapade really needs a 55. A 46LA on an Escapade would be really slow. I'll take a look at the Sky Raider. |
I have a .46LA in a Tower Hobbies Koas I get 10 foot taker off's (Field elevation 4300 ft.) Not a rocket but fast.I also have one in a 40 size super sportster great engine.when coupled with a 11/7 prop.
An Uproar , its a small .40 size plane and you can get it in ARF form from Great Planes. A friend of mine has built 3 of them and loves them.
ORIGINAL: ratshooter Hobbychina I looked at the site you linked and <span style="color: rgb(255, 0, 0);">decided would order an LT-40 ARF</span>. For $58 it is a heck of a deal. The only problem is that you have to order a minimum of 100 units. I like that plane but can't see me needing quite that many in my garage. Can I buy just one or two of them? I might get my flying buddy to buy one also. One more question do you know what they are covered with? |
| All times are GMT -8. The time now is 05:43 PM. |
