Cherokee .40 size question
Does anyone knowhow the Cherokee .40 size plane will fly with a OS 40 engine, is it a strong enough motor to fly this plane, it is the only size engine I have at themomentfor this plane...
Thanks for your comments.... |
RE: Cherokee .40 size question
ive never heard of an OS xp... if its a 40 fp, it will fly it but you will need to get some good ground speed before you try lifting off.... if you are a beginner i suggest you let a more experienced pilot test it out first
thanks MetallicaJunkie, actually the xp was just a typo..lol.. I'm not a beginner pilot, an intermediate pilot at this point in time...
was hoping the 40 size OS would have enough power for this plane... I guess I can always put in a 46 size... |
A friend had the old, kit built version. It flew well on a 40fp.
Check my setup:
[youtube]http://www.youtube.com/watch?v=hPrjAKTfNJs&hd=1[/youtube] |
If you fly it "scale" I think you will be ok.
Long ground run before take off and no insane verticle moves without plenty of recovery room to build speed back up. |
that little 40 is barely enough for this airplane and when you need the extra power to get you out of trouble you wont have it to spare..at the least i would do a 46AX with the max a 55AX engine. I've had both engines in the cherokee and the 55AX was excellent , unlimited verticle are real beast.
Exactly!
I have an FA-80 as you see and i find the power just right. |
1 Attachment(s)
Hi!
This is one of our three trainers we have in our club. Great Planes Cherokee, Powered with a MVVS .40 ,swinging an APC 11x6 prop. Good performance! |
Awesome!
What is that on the 6th pic; |
I have one with an OS 55AX, way more engine than it needs. Years ago the ones built from the kit, pre ARFS, flew fine on a 40.
| All times are GMT -8. The time now is 07:56 AM. |
