RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Hobbistar 60 - Tail dragger conversion (https://www.rcuniverse.com/forum/arf-rtf-75/11294426-hobbistar-60-tail-dragger-conversion.html)
grosbeak 11-11-2012 06:52 PM
Now that the wing repair is complete, I'm turning my attention to the next project for this plane - converting it from conventional tricycle gear into a tail dragger.
The first step was to remove all of the stock landing gear.
http://farm9.staticflickr.com/8294/7...92a30318_z.jpg
http://farm9.staticflickr.com/8298/7...bd923c1a_z.jpg
http://farm9.staticflickr.com/8428/7...0bde8dc1_z.jpg
grosbeak 11-11-2012 07:01 PM
RE: Hobbistar 60 - Tail dragger conversion
Next step: Filling in the main gear channel with some scrap.
http://farm9.staticflickr.com/8429/7...a46e0a2e_z.jpg
I went with a Sullivan tail wheel. The original idea was to have it castering, but a closer look at the tail presented a different solution - taking a notch out of the elevator.
The notch was centred, but the stripes weren't.
http://farm9.staticflickr.com/8484/8...887ff793_z.jpg
Re-covered...
http://farm9.staticflickr.com/8066/8...7436d938_z.jpg
grosbeak 11-11-2012 07:08 PM
After the notch was cut and covered, I ground off the heads of the plastic tail bolts, possible because the horizontal and vertical stabilizers are epoxied in place. Once that was done, I re-covered the tail.
http://farm9.staticflickr.com/8488/8...29d1850b_z.jpg
The tail wheel bracket was mounted with four servo screws...
http://farm9.staticflickr.com/8208/8...aa847249_z.jpg
... and the steering arm was connected to the rudder.
http://farm9.staticflickr.com/8487/8...b89eb6e9_z.jpg
jeffie8696 11-12-2012 05:11 PM
1 Attachment(s)
Cool, Idid the same with my Tower Trainer 40 but left the tailwheel to caster , it worked OK for my flying field but your solution is quite elegant.
The plane flew a lot better as a taildragger but it still sucked and I am glad it finally crashed and burned.
Inow have a Nexstar and its much better, maybe Ican make it a taildragger too?
grosbeak 11-12-2012 07:16 PM
Jeffie, there's a guy named chuebner on RC Canada who has converted his NexStar - check out this post for pictures.
grosbeak 11-13-2012 03:23 AM
On to the main gear. The first step was to decide on the orientation. I chose to have it sweep back.
http://farm9.staticflickr.com/8199/8...2eb4fd67_z.jpg
There are calculations you can do to determine where the gear should go. After a lot of thought, research and advice I decided that placing the axles directly beneath the leading edge (in a level attitude) was the solution for me. To that end, I followed these steps.
[*]Eyeball the placement of the gear on the fuse[*]Mark the leading edge of the gear on one side of the bottom, 5mm from the edge[*]Insert a t-pin at the mark[*]Roughly across the bottom from the t-pin, make a short line parallel to the edge and 5mm from it[*]Pick a forward point on the fuse. Measure halfway across the bottom and insert the t-pin there[*]Measure the distance between the two t-pins[*]Mark the same distance from the forward -pin to where it intersects the 5mm line drawn in step 4.[*]Insert a third t-pin at the mark[*]The line between the two rearmost t-pins forms an accurate leading edge location for the gear
http://farm9.staticflickr.com/8339/8...9a42c973_z.jpg
http://farm9.staticflickr.com/8479/8...f0e68234_z.jpg
grosbeak 11-13-2012 03:28 AM
With the leading and trailing edges of the gear marked, the covering came off the bottom.
http://farm9.staticflickr.com/8347/8...52ca791a_z.jpg
There was a small gap at one point where a razor blade could be worked in...
http://farm9.staticflickr.com/8205/8...37cfc17c_z.jpg
... but first the bottom had to be cut across. A fine-toothed back saw worked well.
http://farm9.staticflickr.com/8341/8...efd97c48_z.jpg
grosbeak 11-13-2012 03:34 AM
With the crosscuts done, a razor blade fit nicely into the gap.
http://farm9.staticflickr.com/8069/8...f9453924_z.jpg
A small scraper soon followed.
http://farm9.staticflickr.com/8345/8...a673367a_z.jpg
With some gentle encouragement, the bottom plate came off the fuse with little damage.
http://farm9.staticflickr.com/8485/8...c5e211db_z.jpg
Turns out I had a hardwood block that was the perfect depth and width - it just had to be cut to length.
http://farm9.staticflickr.com/8482/8...ae3e9bb5_z.jpg
grosbeak 11-13-2012 03:45 AM
I used 30 minute epoxy to secure the block.
http://farm9.staticflickr.com/8480/8...0221beb8_z.jpg
While it was curing, I turned my attention to the gear itself. Drilled out the axle holes...
http://farm9.staticflickr.com/8338/8...e00e0196_z.jpg
... test fit the axles...
http://farm9.staticflickr.com/8060/8...a10065c2_z.jpg
... and marked the centre line.
http://farm9.staticflickr.com/8210/8...39d0b1c9_z.jpg
grosbeak 11-14-2012 06:28 PM
I put the tail wheel on before work this morning - couldn't wait to see how it looked.
http://farm9.staticflickr.com/8066/8...6c351e47_z.jpg
I made a drilling template for the main gear based on the location of the hardwood block.
http://farm9.staticflickr.com/8064/8...2e80d082_z.jpg
http://farm9.staticflickr.com/8070/8...6761124e_z.jpg
Got the holes marked and ready for drilling.
http://farm9.staticflickr.com/8205/8...38b670bd_z.jpg
grosbeak 11-14-2012 06:43 PM
With the holes marked it was time to lug my trusty drill press to the bench.
http://farm9.staticflickr.com/8200/8...a5a43219_z.jpg
A little protection...
http://farm9.staticflickr.com/8198/8...d18a757b_z.jpg
Started with the pilot holes.
http://farm9.staticflickr.com/8057/8...46bc557b_z.jpg
Then to an 11/64" bit for the #8 wood screws.
http://farm9.staticflickr.com/8207/8...86a77a79_z.jpg
grosbeak 11-14-2012 06:48 PM
Time for one of my favourite tools - the transfer punch.
http://farm9.staticflickr.com/8338/8...0e3fa2fb_z.jpg
Holes marked.
http://farm9.staticflickr.com/8068/8...b622a413_z.jpg
Started with a pin vise...
http://farm9.staticflickr.com/8205/8...af7a32cc_z.jpg
... finished with a hand drill and 3/32" bit, marked with tape for a 1/2" depth.
http://farm9.staticflickr.com/8478/8...7005a33f_z.jpg
grosbeak 11-14-2012 06:53 PM
For#8 wood screws I'm not sure it's necessary to pre-thread the holes and drizzle in some CA, but I've gotten into the habit with RC so I went ahead.
http://farm9.staticflickr.com/8483/8...c2302dae_z.jpg
After that came the covering, then the main gear.
http://farm9.staticflickr.com/8485/8...b30a7554_z.jpg
I cut some brass tubing to bridge the gap between axle size and wheel bore.
http://farm9.staticflickr.com/8205/8...21cd12a7_z.jpg
Then onto its new legs for the first time!
http://farm9.staticflickr.com/8206/8...7afd9b09_z.jpg
jeffie8696 11-14-2012 09:37 PM
Irun a lot of four strokes and having the improved ground clearance to swing a big prop is important to me. Ialso fly off tall grass sometimes and it makes a big difference with a tail dragger.
grosbeak 11-15-2012 03:09 AM
ORIGINAL: jeffie8696
I run a lot of four strokes and having the improved ground clearance to swing a big prop is important to me. I also fly off tall grass sometimes and it makes a big difference with a tail dragger.
I hear you. This plane is powered by an OS 65 LA 2-stroke running a 12 x 6 prop, but I whacked the grass with it plenty of times while I was learning on it with trike gear. Had to replace the nose gear a couple of times too.
jeffie8696 11-15-2012 08:28 AM
Ijust hate it when my plane turns green from mowing the grass with the prop. http://www.rcuniverse.com/forum/js/f...ey/msn/lol.gif
grosbeak 11-17-2012 08:38 PM
Together again for the first time.
http://farm9.staticflickr.com/8344/8...c9c380c4_z.jpg
Just a little nose heavy at the rearmost point of the CG range.
http://farm9.staticflickr.com/8341/8...59a7e56a_z.jpg
jeffie8696 11-18-2012 06:54 AM
Looks great, hope it flies as well as it looks.
