RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   New OV-10 project, need help please (https://www.rcuniverse.com/forum/arf-rtf-75/11585750-new-ov-10-project-need-help-please.html)
Tman49 08-26-2013 05:59 PM
Hi all,
I just pulled the trigger on this OV-10, http://www.hobbyhangar.com/hhbaseline_002.htm
I'm going electric on this. I can calculate motor/prop on a plank w/one motor. But how do you do it if the plank has 2 motors/props? Do you just figure two motors that would be about half as powerful if the plank had one motor instead? I don't want to assume the motor in the picture is the best choice for the plane.
Twin_Flyer 08-26-2013 07:40 PM
Cant help with motor choice but as an owner of the same size, but scratch built Bronco, its a great flyer!
might be better if you post in the electric forum though...
Have fun with yours!
Bill S.
Tman49 08-27-2013 07:11 AM
Thanks, will try other forum.
superfli 08-27-2013 07:39 AM
I bought this same plane about 8 years ago. It is a nice model. Go with the recomended motors( .25 - .32 ) electric equivelent. I know if you put in 2 -.32 electrics that would be plenty of power for this plane.
Good luck to you.
Superfli
Tman49 08-27-2013 07:59 AM
Thanks Superfli, did you do counter-rotation on yours? If so, do you just flip the prop or buy a reverse pitch prop? Which one is to be reversed?
Twin_Flyer 08-27-2013 08:03 AM
Why bother? it will limit the prop availability and flipping one reduces its efficiency.
Besides, does the real Bronco have counter rotating props?
Bill S.
Tman49 08-27-2013 08:45 AM
Bill S.
I don't know if the real Bronco have counter rotating props. Good point, I'll research that. I've been reading posts that suggest it's the thing to do when there's multi-engines involved. Maybe that's 4 engines, not two. I'm a newbie on this. I remember something about a counter air flow that cancel out some unwanted effects.
Twin_Flyer 08-27-2013 10:05 AM
With the twin tails you will not have a problem. You will need rudder when taking off, as with any plane and the Bronco will fly with only one engine but you shouldn't have that issue!
just remember to turn it with the rudder and only keep the wings level with the ailerons if you do. i have OS .25 FX engines in my small one, and YS .91's in my large one.
had a conversation with a few club members a while ago about prop rotation. Some twins go in the same direction, some have opposite. Some turn to the right, others to the left. I think most today turn in the same direction to keep it simple for maintenance (both (all) engines the same, etc).
Bill S.
superfli 08-27-2013 10:39 AM
Mine had 2 .40 four stoke engines with regular standard props. No counter rotation.
pattnut 08-27-2013 02:46 PM
The OV-10 (full scale) indeed has counter rotating props. Since you are going electric, it will be easily done. You simply need a "pusher" prop opposite your standard prop, both the same size.
Old Dawg
1,000 hrs of full scale OV-10 "Bronco" time; loved every minute!
Rob2160 08-27-2013 04:48 PM
3 Attachment(s)
Please keep us updated, I have subscribed to this thread. the OV10 is my all time favourite aircraft.
I live in Australia and was a Police Pilot for many years, in planning security for the 2000 Olympics I was the Aviation Security Project Officer, I was in contact with the California Department of Forestry. We almost had a deal with them to borrow 2 OV10's as our Police Patrol aircraft. I had studied the flight manual for weeks in anticipation of an endorsement.
The idea was canned by the Australian Government who didn't want US Military planes flying over the Sydney "Friendly Skies"
We ended up using Citation Jets and Cessna Caravans painted in "gentle" colours. Did the same again in APEC 2007 (pic below of our Police Citation)
I still would have preferred the Bronco!..
If you go with counter rotating props, make sure they rotate so the top of the prop moves inwards and the bottom moves outwards..
IE viewed from the back.. the left engine rotates clockwise. This will give you the best asymmetric performance due to P-factor at slow airspeeds.
http://www.rcuniverse.com/forum/atta...mentid=1913988http://www.rcuniverse.com/forum/atta...mentid=1913989http://www.rcuniverse.com/forum/atta...mentid=1913990
Twin_Flyer 08-27-2013 04:57 PM
That's why I love this forum, there's always something to be learned!
pattnut, im soooo jealous!
Rob, both of my Broncos are in the same scheme as the first pic you posted.
Bill S.
chuckk2 08-27-2013 05:36 PM
Assuming the listed weight is net, not gross -
1500 watts seems about right.
WEBESNAG 01-13-2015 09:43 AM
Here's my 2 cents worth.
I thought you just had to switch one of the 3 leads on electrics to reverse the motor direction.
Steve
P.S. I'm looking for a manual for a hobbytron 48" OV-10 ARF.
jbarnes 01-13-2015 12:36 PM
I bought a couple of these last Fall. Have one flying with Eflite 25's. One pushing, one pulling. Think I have 12 X 10 props, maybe 12 x 8's. Run three cell's stuffed in the front of the fuse. You'll find the kit a disappointment in the plastic parts area. I ended up backing all the plastic parts with a layer of fiberglass. Used the fixed gear that came with the kit. The goofy elevator control was replaced with thin wing servo mounted on the horizontal stab. Flies good. I can only get 2200 batteries in there right now, working on a plan to put some larger ones in for longer flight times. Jerry.
Tman49 01-14-2015 11:18 AM
I had forgotten about this post. I don't get on this site that much. My Bronco project was on hold last flying season. I got 3-bladed 9x7 pusher and puller for it. Using 850kv .25 equivalent motors on 4s. The specs for the motor says it will spin 10" to 14" prop. I believe I got room for 11" prop if I need larger prop. I put retracts on, added Hanger 9 pilots that move their heads w/rudder. I delayed the project until I did research on the long esc/battery wires dilemma. I decided to keep the esc/motor wires short, (for cooling of esc), battery wires are about 14" long. Weight w/o battery (if memory serves me right) is 6lbs. 6oz. I'll double check that.
Anyway, the counter rotating props look great. Amp draw seems ok. Haven't maiden yet, however, the thrust appears very good.
Tman49 01-14-2015 12:22 PM
Jerry, Are the ones you got from Hobby Hanger? I got mine from them w/the military scheme. There's not much plastic involved in the ARF. I'll post pics soon. If we are talking about the same models, what did you find "goofy" about the elevator control?
Regards,
Thomas
