DHC-2 Beaver by E-flite
I need help. I purchased this aircraft, motor, esc, bhc. I have never had to connect a bec before. I'm hearing that the red wire from the esc is suppose to be disconnected and to plug the bec into the batt side of the receiver. I have a spectrum DX6i radio, I don't see a spot for the battery, only for bind/data. Thanks in advance.
The layout of the ESC is usually three wires on one end, these go to the motor, two wires on the other end usually terminating into a plug, and a wired connector like a servo wire. Connect this into the throttle position of the receiver. The red wire in this connector provides the power to the receiver.
I think I left something out. I have an ESC and a SEPARATE BEC. That is my problem. I have 2 connectors, 1 for the ESC and the other for the BEC that both go to the receiver. Some say to disconnect the RED wire from the ESC plug to the receiver and plug the BEC into the Battery port. The only other port on my receiver is the bind/data port, nothing marked battery. Others don't say anything about disconnecting the red wire from the esc.
Sorry about not having all the information in my post. |
I'll give you a tip. Get a small servo extension and remove the red wire. This way you won't have to remove the red wire from the ESC in case you want to use the BEC from the ESC. I used a separate BEC with a Castle ESC a couple of years ago. The separate BEC was also a Castle. I followed their instructions and had no problems. They wanted the red wire out and that's when I used the 3 inch extension.
Thank you. I still have a problem with the receiver. I don't have a separate battery port, I have a bind/data port. Is this where I plug the BEC into?
I researched and found out the receiver bind/data port is for the battery, so that is where the BEC will connect.
As far as removing the red wire from the ESC, I was able to remove the connector in the plug which there is a small plastic clip above the wire that lifts up so you can pull the connector out without any damage and will be able to push it back in. I taped the wire back along itself covering the connector. I want to thank EVERYONE for their help. |
| All times are GMT -8. The time now is 07:30 AM. |
