RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   CA hinges on GP G202 (https://www.rcuniverse.com/forum/arf-rtf-75/131108-ca-hinges-gp-g202.html)
Ron Irving 05-11-2002 02:15 AM
I am up to hinging the control surfaces on my 1/4 scale GP G202
Who has used the CA hinges as supplied in to kit?
If you used them have you had any problems with them.
Thanks in advance
Scorpionjack 05-11-2002 02:25 AM
Never have a problem when I seal the hinge line with clear Ultracote.
http://www.rcuniverse.com/showthread...84&forumid=107]
Dazzler 05-11-2002 02:37 AM
I just went ahead and used the 1/4 scale Nylon hinges with pins. Daz...
echavi9325 05-12-2002 03:54 PM
i have had 15 flights on my giles with os 160
used the ca hinges no problems at all
i used a syringe with thin ca to install them
yagger 05-14-2002 08:35 PM
CA hinges
I dont't know what I did wrong but I was running the engine on the ground without the wing on the body just running the RPM'S up and and lo and behold the rudder fell to one side breaking all but one hinge. Went and bought the large Du Bro hinges and made a piano hinge out of them let me see it fall to the side again.
Dazzler 05-14-2002 08:48 PM
You were lucky yagger, nice choice on hinges now. Daz...
Ron Irving 05-15-2002 11:14 AM
Thanks Guys,
I have decided to use Dubro Heavy Duty pinned hinges and expoxy them in. I will also seal all the gaps.
sillyness 08-30-2002 03:13 AM
Lucky
You're probably lucky that's all you broke. You should never run an engine without the wing attached. The wing dampens the airflow a little, but mainly it is a vibration absorption mechanism!!!
HighSierra 08-31-2002 01:49 PM
It's just easier to put good quality hinges in now rather than latter.... cuz the CA hinges have a far shorter opperational life. Like everyone here I say go with the Dubro 1/4 scale hinges...... and if you really want to do it right.....Make it a piano hinge!! and aways seal the hinge line!!!!
yagger 08-31-2002 05:03 PM
Thanks guys for the input
Yagger
Geistware 08-31-2002 05:50 PM
I have 92 flights on my gas powered GP 202 with CA hinges!
basmntdweller 08-31-2002 07:48 PM
I don't count flights but My giles has to be close to the century mark as well. OS 160 and CA hinges.
basmntdweller
outssider 09-01-2002 04:29 PM
This is really very simple
4 ca hinges per aileron = Disaster
8 ca hinges per aileron = very long life
10 ca hinges per aileron = indestructible / will out live you
HighSierra 09-01-2002 04:39 PM
I think the worse thing about the CA hinges is that say one of them breaks, then you have to sacrafice all of the hinges on that surfacej ust to fix the one......
TIGER2PLANE 09-02-2002 03:39 AM
Do you know that heat and cold will have shorten the life of CA hinges. They will become hard and then break at the most unusual times, and when a bird does come down it will not be the hinges that are blamed but something else.
NM2K 09-02-2002 04:30 AM
My Great Planes Fun One is ten years old this year and is still flying with the original GP CA hinges. Not one single problem in all that time.
Geistware 09-02-2002 04:40 AM
Ok, 95 flights on one and 67 flights on the other and the hinges are great!
rockmon 09-02-2002 11:51 PM
At least a hundred flights on mine with the ca hinges that came with it and not a problem. Do make sure you seal the hinge lines with some clear ultracote. Bob
