GP Giles 202 Engine
I am building er I mean assembling a Great planes Giles 202. I have both a YS-140 and a Saito 182 twin. Which one is more suited to this plane? I have read through most of the threads on this plane and have not seen anyone putting the saito twin on it.
Thanks Dwight |
GP Giles 202 Engine
I have used the YS140FZ in my Giles and it flies great on 15% fuel. It will not give you unlimited vertical. I think the twin would do that. If you run 30% nitro in your YS, it may also give you more vertical!
GP Giles ARF Engine?
How would a 2.4 gasser do in this plane? Is it too much? What mods would be necessary? thanks wc
I'm planning in going with...
A ST 3250. Should be a monster!
Jon |
GP Giles 202 Engine
If you put an access hatch in the tail to install everything except the throttle servo it is great. I have put about 10 oz in the tail to get the balance at 9.0-9 1/8 of an inch. The plane flies GREAT
| All times are GMT -8. The time now is 06:33 PM. |
