RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   H9 AT-6 Texan Engine Mounting (https://www.rcuniverse.com/forum/arf-rtf-75/1545221-h9-6-texan-engine-mounting.html)
ChopperDude 02-19-2004 08:31 PM
1 Attachment(s)
Hey, I am struggling a bit with mounting a Saito .91 on my Hanger 9 AT-6 Texan. This is my first 4-stroke so I'm not sure. It is mounted at a 45 degree down inverted with the muffler down and back. Does this look right in the photos? It seems I will have to cut alot of cowl for the heads and muffler...Bill
bearmech 02-19-2004 09:51 PM
RE: H9 AT-6 Texan Engine Mounting
If you turn your mount 90 degrees the muffler will exit out the bottom and not be as noticable. I installed a magnum .91 on a T-6 this way last year and it only needed a hole the size of the rocker cover on the lower right side of the plane and a little lager hole on the bottom.
joshmoha 10-06-2004 08:00 PM
i am mounting my engine and it looks like its to far below the carb wont it flood itself thanks
P-40LUVR 10-07-2004 09:38 AM
That just doesn't look right,I would have mounted it at a 90 degree(sideways) or 180 degrees inverted.
I read about a guy that had a Saito that would not run inverted very well though, I run Magnum and OS 4 strokes inverted
and they run just fine.
Is that the way the engine mount was attached from the factory?
cruzomatic 10-07-2004 08:03 PM
ChopperDude, I have mine the other way, leaning toward the left with the muffler pointing straight down. I'll look for some pics to post. :D
cruzomatic 10-07-2004 08:06 PM
1 Attachment(s)
Here you go. Notice the muffler pointing almost straight down.
