WHAT SERVOS TO USE
I have the vector flight Edge 540, 66 inch wing. Have put a magnum 91 4stroke on it. Do you think standard servos have enough power to handle this airplane?
All imput welcomed, Thanks Wings nh. |
RE: WHAT SERVOS TO USE
ORIGINAL: wingsnh I have the vector flight Edge 540, 66 inch wing. Have put a magnum 91 4stroke on it. Do you think standard servos have enough power to handle this airplane? All imput welcomed, Thanks Wings nh. Good luck, Dave Olson |
If you push it much,servos with 70+ ounce torque may be saver.Is one servo running the elevators?this is one place to pay special attention.A single standard here ,is not a good idea
With an engine that size, yes, it will be enough.
a cheap fix for getting more torque is to go to 6 volt battery i have an ohio models profile 540 with standard hitec servos and 6 volt battery and and no problems
Look's like standard hitec servos on the 6 volt system ma be the way to go.
Are there any special considerations when going to 6 volt? Thanks, wings nh. |
no not with hitec anyway there servos and reicevers operate at 6 volt i called hitec when i decided to run 6 volt and they told me no problem and that i would get about a 20 percent incr. in torq and speed
| All times are GMT -8. The time now is 01:43 AM. |
