RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   H9 1/4 scale CAP 232 and Robart Hinge Points (https://www.rcuniverse.com/forum/arf-rtf-75/158485-h9-1-4-scale-cap-232-robart-hinge-points.html)
GalenB 06-10-2002 03:17 AM
Hello,
Has anyone used the Robart hinges on their CAP? If you did -- what size did you use and how well do they work?
TIA for your help.
Cheers!
Galen
CAPtain232 06-10-2002 10:06 PM
Galen,
I am sure the Hinge points would work well, but the CA hinges are just fine. I have built 2 of these planes with gas engines and NEVER a problem with the CA hinges.
Jeff
KidVermin 06-10-2002 11:18 PM
Galen:
Go with the 310 size Robarts. Rub the elbow joint with chap-stick
to prevent epoxy from getting into joint.
I glue mine into the main surfaces first. Making sure they hang
down square with the trailing edge. Once cured then attach the control surfaces.
Randy
Woody218 06-11-2002 12:09 AM
If you're worried about the stock CA hinges, you can get CA hinges for large-scale aircraft, they are distributed by Radio South.
GalenB 06-11-2002 02:38 AM
Thanks to all who replied. I am not worried about using CA hinges on this model. There have simply been too many successfully flown for there to be a problem (for me not to know about it via these forums -- that is! :D). It's just that I've done CA hinges, and done iron on gapless hinges and wanted to give the Robarts a try. I try to push my knowledge a little with each model that I build. Even if it's only assembling an ARF...
Cheers!
Galen
