RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   H9 T-34 Tail Problem (https://www.rcuniverse.com/forum/arf-rtf-75/1666219-h9-t-34-tail-problem.html)
pdansalvish 03-27-2004 10:58 PM
Hi,
Today I went to maiden my wifes's H9 T-34. Running a Satio 72 for power and installed the H9 retracts. Halfway through the initial flight I retracted the wheels and was about the give the plane to my wife to fly. So, I put the plane into a mild diving bank to bring it lower and to make a pass of the field. During the banking turn we heard a loud "Pop" and pieces started fling off the plane. Don't know how but I was able to belly land the plane. When we looked the plane over we determined the fin pulled away from the plane and the bottom of plane was gone. Fellow club members were able to retrieve the fin and we all started to examine it. Our first thought was the glue joint gave away. But, that was ruled out, because the bottom of the fin was covered with foam and was past the glue joint. We checked the hinges and they had some wood on them, so I don't think the hinges failed on the rudder (but we haven't ruled faulty installation of the hinges). I was flying aroung on 1/2 throttle on the stick and the manuver was a low 'G'. At this point, I'm taking the plane to our LHS which is offical Horizon Dealer and leave them determine if the problem was ours or Horizons. I did hear through the grape vine that our LHS had to retrun a few H9 T-34 because of a tail problems encounter at another club. Who knows they may have another one. I will keep you posted.
Flyin4Fun 03-27-2004 11:15 PM
RE: H9 T-34 Tail Problem
1 Attachment(s)
24 flights of hard yanking and banking on mine and still going strong.....................................;)
I went over the plane before i assembled and re-inforced any all-ready glued joints with epoxy for added strength.
Also after reading your post went and double checked mine before flying today and have no signs of problems with the tail area.
Hope you find out what happened. It sure is a nice flying plane. Gets nothing but great coments at the field.
Magnum 70 4stroke
H9 Re-tracts
Airtronics RD6000 Super equiped.
Ed;)
pdansalvish 03-29-2004 10:31 PM
Well we think we might have found the another possibilty. On the nylon clevis holding the rudder the pin was almost broken off. What we don't know if it happened before or after the seperation. But, in the mean time, I order replacement parts, cowl, tail cone, and decals. It will take awhile, but I'm confident it will get airborne again. This time with a few mods.
tailskid 03-29-2004 11:33 PM
What did they charge for the cowl? I 'dented' mine - ON PURPOSE of course :)
Jerry
pdansalvish 03-30-2004 09:45 PM
Jerry,
I will be picking up the cowl next week when I come back from Toldeo. I will let you know then.
Dave
