RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Aresti info needed.... (https://www.rcuniverse.com/forum/arf-rtf-75/171258-aresti-info-needed.html)
Eam201 06-22-2002 11:52 AM
Hey one of my buddy's has acquired this very nice looking plane H9 Aresti. on one of his first flights the wing fell off and the plane crashed to the ground! The wing hold down does not look like it was glued in. Has anyone had this trouble with this model?
Blackie 06-22-2002 08:50 PM
I have one but have had no problems. Flys great
Randy
Dennis Tampa FL 06-23-2002 01:04 AM
Search aresti I heard latley some complaing or worring about that the wing/area looked weak.
F900 06-23-2002 01:38 AM
Aresti
Before i sold mine, flew it stock, many flights and no problems. maybe the screw was not tight as it needs to be.
bgi 06-30-2002 03:19 AM
Flew mine today for the first time. No probs. Great plane! Doesn't like to slow down, though...
Here's a trick for you Aresti owners: Mount a Hobbico Volt-Watch INSIDE the fuse in the plywood opening just above the wing - tape it in place with box tape on the Ultracote. It will show through the white Ultracote. Cool!
BTW: I think the recommended low-rate and high-rate elevator throw isn't quite enough. My first mistake with this plane was taking off with low rates - almost didn't have enough elevator to lift off over the weeds. It shows no tendancy to snap at high speeds with full up elevator.
The OS 46-FX is enough engine for this plane - it's really quiet.
