RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   venus (https://www.rcuniverse.com/forum/arf-rtf-75/177083-venus.html)
RickC2009 06-27-2002 08:19 PM
venus
got mine almost done. Anyone use an Os 70 4 stroke? How does it balance? Where is the Bat and RX?
RickC2009
MMallory 06-28-2002 11:52 AM
venus
Rick,
With a TT .46 mine balanced without additional weight with the battery at the rear of the wing and the receiver at the front of the wing.
Mark M.
HighRPM 06-28-2002 12:19 PM
venus
Mine has a O.S. .61 and I had to add considerable weight! Flies great still.
RickC2009 06-28-2002 06:16 PM
venus
Mark
How does it fly with the tunder tiger 46?
I was first going to use a TT 46 but then changed my mind to an os 70 I just like the longer run times and you can always use some more power! But if I will run into a CG problem I might go back to the TT46, that is if you think it's enough power!
rickC20089
MMallory 06-28-2002 06:42 PM
venus
Rick,
It will fly very well with the .46. You will not get unlimited vertical, but, you will be able to do everything it was designed to do. I think the perfect engine would be the YS46.
Mark M.
RickC2009 06-28-2002 07:17 PM
servo
Anyone ever thought of putting the rudder servo in the bottom of the fuse by the tail using pull pull?
bentgear 06-28-2002 08:02 PM
venus
Rick,
With most engine that would mean you would have to add about 1/2 pound of lead at the nose to balance the thing, at least you would on either of mine.
Ed M.
