RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Oops!!! What would you do? (https://www.rcuniverse.com/forum/arf-rtf-75/1796696-oops-what-would-you-do.html)
Dig it 05-08-2004 12:47 AM
K, I'm just about done my Seagull Extra, but, I put the fuel dot too far back and it hits the firewall. Now. I can leave it as is and the engine will fit through the hole it is supposed to, but I'm thinkin that if I just carve out a small bit of the firewall and maybe do a little reinforcing that I can move the cowl back as far as I would like and all should be good. What do ya think. Would cutting into the firewall (and doing some reinforcing) be a good idea or should I just do with what I have?
Vortec 05-08-2004 02:02 AM
RE: Oops!!! What would you do?
Just take some wood off the fire wall there is heaps there.If your going to reinforce it, it not realy going to hurt.
Norm Nestie 05-11-2004 11:08 PM
Well, I did that once as well. I would move the fueler forward on the cowl, cut apiece of ply or balsa and glue into first hole. A little filler and some paint will fix it up. A lot easier, IMHO. I have the same plane on order, can hardly wait.
