RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Stinger ARF (https://www.rcuniverse.com/forum/arf-rtf-75/2147085-stinger-arf.html)
henryhighwood 09-04-2004 07:19 PM
Stinger ARF
I see the Stinger series advertised all the time, but don't see them mentioned here. Any opinions about them? I am interested in the 60 size. How do they handle? Fast? Slow?
I had built a stinger 10 long ago and thought it was a quirky flier and am just wondering what the larger ones are like.
Thanks for any suggestions.
John_RedSox 09-04-2004 08:34 PM
RE: Stinger ARF
I have the Stinger 60 size plane. It's on it's third year and it's a great flyer. Way overpowered with a 91 two stroke. With the thickness of the wing, in my oppinion, bad habits are hard to find with this one. You will enjoy this plane.
Gizmo-RCU 09-05-2004 08:46 PM
RE: Stinger ARF
I have one I built 4 years ago. Good flier and predictable.
I do not like the crappy plastic and foam construction and feel it takes away from an otherwise nice plane. It is not a 3-D plane if thats what you want, I have a very nice Magnum 91 FS on mine that does the job well. This is a somewhat heavy plane....
eric wilson 02-12-2006 12:22 PM
RE: Stinger ARF
I have been flying my Stinger 60 for about six months, on an almost daily basis. I've got a Evolution 1.0 on it and it is a real hoot to fly! In my opinion, you can't go wrong with it for a second or third plane.
SigFan 02-12-2006 07:34 PM
RE: Stinger ARF
I had a stinger 60 ARF with a TT .91 in her. It's a nice flyer, no bad habits. Lands a little fast. but mine was balanced on the forward end. The tail wires are a must and they tend to be nose heavy. I made a shelf and put the battery in the headrest. Not overly fast, comperable to a stick maybe in speed and handling. It's a nice plane, good luck.
w8ye 02-12-2006 10:21 PM
RE: Stinger ARF
Nice all around plane. Heavy but that males it a little better in the wind.
The plastic needs to be backed by 3/4oz fiberglass and PVC pipe cement.
It a older design that has been around for years.
Makes a good casual plane.
Enjoy,
Jim
SigFan 02-13-2006 05:07 PM
RE: Stinger ARF
I wanted to mention that the stinger 60 kit and the 60 ARF are two different animals. The ARF is a built up, all wood model with fiberglass cowl and wheel pants. Not to be confused with the ABC plastic parts and foam wing of the kit.
It's one of the few exceptions in models where the arf is actually better than the kit. I found it to be realivly light for a 60 sized plane, mine came in at just over 7 lbs. The only problem I found with mine (other than the tree I knife edged through!) was the star stickers for the wings peeled off as soon as a little fuel residue came into contact. Skip the stickers, other than that a keeper.
AcroJo 02-13-2006 05:43 PM
RE: Stinger ARF
1 Attachment(s)
I had the .60 arf a couple years back. Now all I have is the custom cockpit that I did for it and some tail feathers up in the rafters. Joe
imsofaman 11-04-2006 09:17 PM
RE: Stinger ARF
1 Attachment(s)
I got my Stinger back finally. I sold it a few years ago, it went thru 3 owners and the last owner lost control and pancaked it with lots of damage. It was given back to m ewith lots or work....I got her flying again. For power, tried out the Magnum 91 and like it very much. With a low pitch prop....I find it 3D capable....not your hard core 3D, but it will hover and other fun tricks. I like it and I am so happy to have back home!!!!:D
Tango Juliet 12-16-2008 11:49 AM
RE: Stinger ARF
Does anyone recall what the thrust angles should be for the engine on the ARF? I have one, but I need to cut out the firewall and replace it for a different engine and configuration.
5478jimmy 04-26-2009 10:14 PM
RE: Stinger ARF
Can someone tell me what the center of gravity is on the stinger 60?
imsofaman 04-26-2009 10:19 PM
RE: Stinger ARF
I cant find my stinger book. The original book I had.....they said the CG was wrong. I will have a look for it in the morning. I scribled some notes in it....
Dave
w8ye 04-26-2009 11:48 PM
RE: Stinger ARF
the CG should be at the trailing edge of the wing sheeting
Thrust offset is usually 2 degrees down and right
