PITTS MUFFLER ? HELP
my question is i have a OS61FX in witch i have installed on my seagul extra 300 with a pitts muffler.I have recently just join a club in witch theres a noise requirement, and of coarse i dont want to piss any one off and i want to enjoy flying there and go buy the rules..... well my question is i dont wont to ruin this planes looks by hanging that big ugly looking stock muffler off the side,and take away any of the performance.... could i or has any one every stuffed steel wool in the pitts muffler to quit them down so i wont have to remove it ? or make another suggetion on how to tame Her down thanks in advance Bill
RE: PITTS MUFFLER ? HELP
put on two rubber exhaust deflectors or crimp the outlets a little bit, bigger prop
Tried steel wool in 2 stroke glow exhausts quite a few years ago. It reduced the noise level a fair bit, but had a tendency to restrict the exhaust flow a lot. I figure this was because the oil expelled by the motor coated the individual 'fibres' of the steel wool, clogging it up eventually, - used to ooze oil out for weeks after as well.
Why not try secondary expansion chambers attached to each outlet of the pitts exhaust. Good silencing effect with much less loss of power! Regards Andy E PS You have to be REALLY careful that bits from the steel wool do not find their way back through the exhaust port, it aint too good for the piston and liner!!! |
andy who makes the secondary exstentions im new to the hobby and was not aware they made such a part
FWIW, I have an OS .61FX in a 1/4 scale Spacewalker with a pitts muffler and it ain't any louder than engines with stock mufflers. Not enough to notice anyway. ;)
All Pitts style mufflers are loud, even your Rossi mini tune pipes. You best option is to be a nice boy and take off with as little throttle as you can get away with and then fly high! :) There is no option to silence a Pitts style muffler, it does not have a baffle.
ORIGINAL: SENZA andy who makes the secondary exstentions im new to the hobby and was not aware they made such a part One company that does them here is called Just Engines. Link below! [link]http://www.justengines.unseen.org/sils2.htm[/link] Cheers Andy E. |
| All times are GMT -8. The time now is 05:42 PM. |
