Props
One question that I hope someone can answer. Why do most of the real warbirds have a 3 blade prob but the RC versions use 2?
RE: Props
from what i know rc airplanes don't fly well with 3 blade props. correct me if i'm wrong
RE: Props
The war birds of old needed the ground clearence. The F4U Corsair for example went from a three blade to a four blade as horse power increased. The gull wing gave some rough duty ground clearance but a more efficient two bladed prop would have to be nearly twice as long. The more blades the less effective. A one bladed prop would actually be better than a two. It might be a bear to balance though.
David |
RE: Props
Ok, it makes a little more sense. Could I run a three blade prop on a .60 stuka with a saito 100 4 stroke?
RE: Props
what size three blade?
RE: Props
The drop in efficiency is caused by the blade moving through the turbulence created by the blade in front of it.
The more blades the more the turbulence (since the blades are closer) Three and four blade props look cool though! Terry |
RE: Props
Eeeerrr ... does anyone see if its a 3 or 4 or 2 bladed prop when the plane is flying? :)
RE: Props
ORIGINAL: Draco One question that I hope someone can answer. Why do most of the real warbirds have a 3 blade prob but the RC versions use 2? If you want to swing a large multi-blade prop, then use an RCV "SP" engine since it swings the prop at only around 5000 rpm, which gives you back some efficiency. |
RE: Props
ORIGINAL: Draco Could I run a three blade prop on a .60 stuka with a saito 100 4 stroke? |
RE: Props
Richard, thank you very much for the info. I makes a lot more sense now. One last question for you. For the 60 size plane, should I use the Saito 100 or 120?
RE: Props
The Saito 100 would be plenty for the 60 size plane. Even the Saito .91 would be more than enough.
RE: Props
1 Attachment(s)
NO WAY would I run a 2 bladed prop on my P-40'S..just doesn't look right..I just put big 4 strokes in little planes.[sm=lol.gif]
RE: Props
Gray 3-bladed prop doesn't look right either ;) Curtiss Electrics are black with yellow tips.
http://www.whitetyphoon.com/rc/vq_p40/pic11d.jpg |
RE: Props
The 1150 HP Allison engine stripped the black paint off the prop![sm=lol.gif]
RE: Props
Another thing to consider is engine load vs. thrust, both on model engines and full size. If you want a scale prop , an engine at the upper end of the range for your model is much better. A three or four blade prop will provide more thrust at a given rpm than a two blade of the same diameter(and pitch), even given the reduction in efficiency, allowing lower engine speeds for a specific airspeed. In a glow engine the danger is overloading the engine, causing overheating and/or detonation. A four-stroke is more desireable for lg. diameter or multi blade props because it develops its max torque at lower rpms than 2-strokes. Turning larger diameter props at high speed is noisier, too, because the prop tips are running closer to sonic speed, and they lose efficiency that way, also.
| All times are GMT -8. The time now is 06:37 PM. |
