RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Modeltech P47, first glitch... (https://www.rcuniverse.com/forum/arf-rtf-75/2960966-modeltech-p47-first-glitch.html)
Fastsky 05-10-2005 08:17 AM
Installed the serevo plate and was happily ready to bolt in the tail gear assembly last night. I installed the 2 bottom bolts and then found out that the 2 top blind nuts are not installed far apart to get the bolts in. Put the plane away to think things over. I was thinking of just leaving the gear attached with just the 2 bottom bolts. Now I think I will take the plastic piece out and just move the top 2 holes in the piece of plastic up about an 1/8" and then get the thing installed. Bit of a nuisance but its making things work thats part of the fun. ;)
cruzomatic 05-10-2005 09:24 AM
RE: Modeltech P47, first glitch...
No worries. The same exact thing happy to me and my Model Tech P47 while setting up the tail gear assembly. Must have been a factory glitch or something. Just use two of the bolts, but add some loctite to them before inserting them. You'll be fine. Mine are still holding strong.
Nice flying plane. What's your setup going to be? I have a Magnum 120RFS spinning an APC 15x8 on mine and flies at 1/2 throttle. At full throttle it's very, very fast. Landing are nice and slow. Good luck.
Fastsky 05-10-2005 10:51 AM
Thankx cruz!!! I bought a Kange SK80 ringed 2 stroke engine for it. Haven't figured out which prop to go with it. I bought some Futaba BB servos which I will be installing tonight. May have the whole thing finished by the weekend. :D
dan4466 05-10-2005 01:01 PM
Same thing with mine. I used a little CA on mine also.
cruzomatic 05-10-2005 01:14 PM
1 Attachment(s)
Keep me posted. If you need other help, let me :Dknow.
cruzomatic 05-10-2005 01:15 PM
Hey, can you guys do me a favor and check the enclosed decal sheet that came with the plane. I think I may have lost one of the "Bonnie" decals,,,,,,or did it come with only one?
gnirwin 05-10-2005 04:39 PM
came with only one
cruzomatic 05-10-2005 09:59 PM
Only came with one "Bonnie" decal huh? [:o] Okay, thanks.
dan4466 05-11-2005 02:15 PM
gnirwin is correct
rifraff 06-16-2005 01:25 AM
1 Attachment(s)
thats a very nice looking plane,check mine out.. i have an O.S 61, an 11\7 three blade prop.robostruts and it flies great
cruzomatic 06-16-2005 03:00 PM
Nice looking plane. Tell us about the retracts, specs?? Who makes them? Also, like those .50 Cals on there. Is that brass tubing?
Cyclic Hardover 06-16-2005 05:44 PM
1 Attachment(s)
I made my own decal
rifraff 06-22-2005 10:24 PM
thanks i uesd the mechanical retracts that came with the plane,i just added the robostruts ,and yes it is brass tubing for the guns i have to take some new pics of the plane,i painted the guns and i had a little accindent with the wing i was putting everything away and the wind picked up my wing and dropped it on top of my hanger9 p40 prop blade,it whent right thru the wing
just a nights worht of repair and back in bussiness
a65l 06-23-2005 06:56 AM
I just took the dremel tool to the t/w bracket and elongated the holes. My real problem was that the way the tiller arm was bent, it was binding the tail rotor servo. I bent it the other way and works fine.... could have used an r/c car brake setup as well, I suppose.
Andy
Fastsky 06-23-2005 07:58 AM
I got a replacment for the tail wheel assembly after the nylon piece shattered when the tail wheel got pushed a little too far. The second one broke when I had the control rod attached and I just pulled on the control rod at the seervo end when I went to straighten the tail wheel. It shattered into little pieces! Removed the mounting bolts and pulled the broken bits out and the control rod. I made a plywood mounting plate for a Sullivan tail wheel assembly and am going with that. No more fussing around and the Sullivan setup works everytime. I am going to talk to Global about the fragile landing gear and see if they will refund my money for the flimsy part!:eek:
