RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   GREAT PLANES STUKA (https://www.rcuniverse.com/forum/arf-rtf-75/3040829-great-planes-stuka.html)
yellowred 06-04-2005 04:38 AM
GREAT PLANES STUKA
Hi, i'm just about to give the great planes stuka its first flight, 72in span, fitted with irvine .72 2stroke, any feedback would be helpfull, the reviews all say its good????????? it has built in right trust in the firewall but it also seems to have some up trust??
Fastsky 06-04-2005 02:13 PM
RE: GREAT PLANES STUKA
Hi yellowred! You do have flying experience, hopefully some low wing tail dragger experience?? On the Stuka, I am flying mine with a Tower Hobbies 75 and it has tons of power so your Irvine 72 should be a good match. I never checked the thrust line on mine, just installed the engine and everything works well. On the throws, I read that the ailerons have very little authority if set up to match the manual. Most flyers are *****g out the aileron throws to get better response. I did that and have about 1 1/2" in both directions. Its a lot but the plane handles very well and turns as fast as a standard sport plane because ot it. The rolls are still slow but you can't have everything. I have flown mine inverted across the field with no problems. I am still getting used to mine so I have the flaps connected and have been leaving the flaps up. From other Stuka owners I read that the plane tends to nose over unless you bend the main landing gear forward a bit. I did this in a vise before I mounted the gear into the wing. I got about 1 1/8" forward bend and this mod seems to do the try because ground handlying is very good. Take off, throttle up and hold a little up elevator until the plane starts moving. Then you can ease off to center and watch the plane gain speeed. Now I don't know if its just my Stuka but my plane will gain speed quickly and suddenly lift off on its own in about 100 feet. The plane the plane is much faster than I expected and I tend to fly at under 1/2 throttle to keep the speed down. The wing shape is very distinctive but most owners have added something like yellow stripes to help see whats happening. I did this to help on cloudy days. Some things to note thats handy; the plane will self level very quickly if you let go of the sticks. This has helped me a few times when I let the plane get out a bit too far and wasn't sure what was happening. Another thing the plane has a big wing and is light. It can fly at trainer speeds with no worries. For landing I just cut the throttle, line up and land about the same speed as my original LT40, and thats without using the flaps. Don't forget to flair and the landings will look very cool! Overall its a very easy plane to takeoff, fly, and land, and its a nice size. I really like mine. I found out that the plane is easy to fly in the wind. The thin wings just slice right through it and I have made almost hover landings in very windy conditions. For interest a fellow Stuka emailed me some short videos of his Stuka during takeoff, and some landings, very nice! I can email them to you if you are interested. Any other Q, feel free. :D
yellowred 06-05-2005 02:31 AM
Thanks fastsky, yes i have l plenty of flying under the belt , its very nice to get the low down from someone thats been there, i havent bent the landing gear but i will now thanks, i will also up the throws on the ailerons, you must have been happy with the c g position, and yes i would like to see the video, Thanks for your help...next up is a flair thunderbolt!!!!!!!!
Fastsky 06-05-2005 09:43 AM
yellowred, I forgot to mention about the CG. The pleasent surprize was that it balanced perfectly with the battery pack just behind the fuel tank! Another thing I check was the lateral balance. It stayed perfrectly level when I checked it! I'll emaily you info on the videos. [8D]
yellowred 06-05-2005 10:21 AM
MANY THANKS!!!!!!!!!!!!!!
kmtranmd 06-05-2005 03:01 PM
I have GP Stuka with Magnum 91 4C. It's an easy, medium speed flyer. It rolls slow so make sure you don't do it at low altitude. The gull wing looks great in the air. Mine lands a bit fast until I use the full flaps then it slows down well. It's stable on take off you you should be able to lift at 1/2 throttle for more scale look. It's an excellent first warbird. I'm more of a spitfire and P51 flyer. I like the faster warbirds. I'll sell mine if anyone really wants one.
yellowred 06-05-2005 04:16 PM
Hi GI Doc, Thanks for your info, did you move the landing gear forward to stop nose overs, and did you notice the thrust line any up thrust?????????/ Thanks!!!!!
scaleMan 06-06-2005 02:24 AM
1 Attachment(s)
I didn't bend the gear at all. I just installed them as per the instructions and have not had any problems with nose over at all. I also installed a super tiger 61 as per the instructions. Flys awsome and lands so slow with full flaps...
scaleman
yellowred 06-06-2005 02:36 AM
Thanks scaleman, my fist flight will be wednesday, your flying site looks fantastic and so does the stuka on the runway!!!!!!!!
paladin 06-06-2005 07:14 AM
TRy this site.
http://www.rcuniverse.com/forum/m_10..._1/key_/tm.htm
