Avistar replacement
Just to shout out about Hobbico. I recently was pulling out of
inverted flight and my Avistar 40's wing buckled and broke in half ! So sad {poor trainer} ,But I sent the wing back to Hobbico and I'll be a son of a gun , They sent me a new plane today! So as far as standing behind there product goes, Go Hobbico. |
Avistar replacement
Glass the wing on your new one.
Avistar replacement
New one has a steel rod through it and I put epoxy on it.....
Avistar replacement
Sly_1
I epoxied mine too. It bent after about 5 flights. I ended up glassing the center section (after straightening the rod) and haven't had any further trouble. I'm amazed how much stress is put on the wing - I wouldn't have expected it....... |
Avistar abused
I oened up the the wings and installed mounts for the struts I built and anchored to the factory landing gear holes. Moved the gear forward(tail dragger now) and built a single set of wires on the tail feathers. Put in a Saito 72,which pulled the fire wall loose and required a little beefing up, and now we give it anything you can think of and it hasn't failed yet. A lot of fun to fly.
Avistar replacement
It seems that several of the ARF MFG's are getting good press by standing behind there products. If SIG did that on the Sukhoi, I would own one now.
| All times are GMT -8. The time now is 05:46 AM. |
