U can do 46 elevator setup
I am just finishing a U Can Do 46 and the plans instruct you to put the control horns on the tops of the elevators and then use a reversing Y connector. Is there any reason why I couldn't put one of the horns on the bottom of the elevator and use a standard Y connnector. My LHS is out of reversing Y connectors and I was hoping to fly it this weekend since I already have a standard Y.
Thoughts appreciated dave |
RE: U can do 46 elevator setup
I didn't use a Y connector on mine. I ran servo extensions and plugged one elev. half into the Rx gear port and the other into the elev. port and mixed gear to elevator in my Tx. I don't like Y connectors. Using separate channels for elev. halves allows for individual fine tuning .
I thought about doing that ( I'm using a Futaba 7CAP radio) but I could find an example in the manual. I will have to play around with the custom mixing features.
Dave |
:)It doesn't take any kind of a special mix. Put Right elevator in Ch 2 and Left elevator in Ch 8 or Ch 7 if you don't have an 8 channel receiver. Should be able to activate AUX channel (7 or 8) and everything should work. Then you will have to adjust a little bit to get them working at the proper/same speed and travel. Not all that hard really.
thanks, Barry |
Barry
My radio only allows you to assign channels 5 &7 to switches A-G not to the sticks. Dave |
1 Attachment(s)
I had mine set up originally with a Y harness and one of the horns up and one down. It works, it's just set up in a weird angle, but it does work.
:)Cee Gee. That troll got any clothes on? Maybe you better paint the canopy. Now I know what you are hiding.
Thanks, Barry |
Barry,
I did figure how to do it with a custom mix of gear and elevator. Cee Gee's went for the beast with the Troll, I went for the beauty. My cockpit has one of my daughter's Barbie's, with no clothes. dave |
Use a reversible Y-harness with the Futaba 7-CAP . Believe me ,, it's better. You can't adjust elev trim equally while in flight with the 7-CAP. You do have aileron mixing that works perfect. But Futaba doesn't put in the correct elev mix features in radios less than the 9-C, etc.
And no,, I didn't post this because it's my thoughts or idea. Got it right from Futaba's website. |
ORIGINAL: Barry Cazier :)Cee Gee. That troll got any clothes on? Maybe you better paint the canopy. Now I know what you are hiding. Thanks, Barry |
Kurt
Thanks for the info. I found exactly what you stated in the FUTABA FAQ on the 7 -cap. I will use the Y harness Dave |
| All times are GMT -8. The time now is 08:15 PM. |
