RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   RYAN STA-M--Ryan STA (https://www.rcuniverse.com/forum/arf-rtf-75/3511320-ryan-sta-m-ryan-sta.html)
Brian Smith 11-01-2005 03:11 PM
Any one know for sure if the Robo struts for a 120 Version of the GP Ryan STA-M are the same Robo struts as the Ryan STA civilian version? Thanks. Brian Smith
Ryanfan 11-01-2005 05:56 PM
RE: RYAN STA-M--Ryan STA
Yep, the same ones.
Ryanfan
Brian Smith 11-01-2005 06:10 PM
Thanks friend..... Brian
Brian Smith 11-01-2005 06:35 PM
BTW..Do/did you use a set? Are they worth the money over stock? Thanks "AGAIN" Brian
ORIGINAL: Ryanfan
Yep, the same ones.
Ryanfan
Dick T. 11-01-2005 10:42 PM
1 Attachment(s)
Brian,
I used a set for three seasons on the STA. First flights used the stock gear but I found them to be bouncy and unable to take much side load. A new set of pants and the Robarts took care of all gear issues and kept the STA in perfect shape for the remainder of time I owned it.
They are a bit pricy but keep the pants and airframe from abuse.
til 11-02-2005 08:39 AM
can you tell me which ones to order please
til
alfie43 06-16-2006 10:41 PM
Dick,
I am currently building (should I say...assembling) a Great Planes Ryan STA. I love the markings on yours. Where did you get them great decals? Thanks in advance.
Alfie
Dick T. 06-16-2006 11:24 PM
1 Attachment(s)
I produce the custom vinyl decal set which includes your AMA number as large outlined NC numbers for upper and lower surfaces of the wings. Send me a direct email and I will send a pdf showing everything in the set.
Mikel-t 06-18-2006 08:16 AM
Second that Dick T, those decals really stand-out, I am going to follow alfie's lead and drop you a line. BTW any thoughts on using RCV 120 for power? Thanks mikel-t
Iflyglow 06-18-2006 09:51 AM
You would have to do some firewall work.:eek: I ended up glassing the firewall coners, because my YS wanted to fly by it self, and allmost did. The firewall was loose after 20 flights. It is installed with hot-melt[X(] not epoxy.
I too had the robo struts, and never even tried the stock gear.
Dick T. 06-18-2006 12:18 PM
I think the RCV would be fine although I have no experience witht them.
My Ryan us powered by a great running Magnum (ASP) 1.08 with onboard glow. I mounted the engine about 15 degrees off inverted, made a 90 degree elbow and used the stock muffler. It all stayed within the cowl.
The 1.08 provided ample power for any type of flying. Interestingly the Ryan will knife edge better than a lot of 3D airplanes!
